Power trunk release
Old Nov 16, 2010
aspork42's Avatar
aspork42 is an unknown quantity at this point
Power trunk release
Hey guys,
Finished installing this remote start in the Honda. I used one of the Aux outputs to activate the rear defroster. This is a pretty cool setup. The remote has a digital display, and features two-way communication to your car. It will show you if the car is in range; it can show you the current temperature in your car; and you can program the clock on it to start your car at the same time every day.
Anywho,
I want to use it to activate a power trunk release on the car. As far as I can tell, 7th gen never had a power trunk option, if I'm wrong, please let me know. I have already run the 12v to the trunk lid (through a relay) and want to mount an actuator like this which I already have, and use that to open the trunk. I would much rather use a factory-style latch, but this appears to be the best option.
I have a project box to hide the actuator in, and a friend that does body work. We are going to fab a bracket to hold the actuator in the box in whatever seems the most optimum position. I want this to look as 'factory' as possible.
Here's my questions:
Has anyone else done this before?
Does anyone have any suggestions?
Old Nov 16, 2010
aspork42's Avatar
Re: Power trunk release
Wow,
Research fail: http://www.handa-accessories.com/acc...runkopener.pdf
Looks like I may (or may not...) be spending the $30 to get an Accord trunk release. Maybe I can find one at a boneyard for cheaper.
Thanks guys!
Old Nov 16, 2010
CGaud's Avatar
CGaud is an unknown quantity at this point
Sounds like a pretty dope set-up. Do you have a diagram that shows the connections you made to use AUX for the defroster? I'm interested in doing something similar when the time comes.
Old Nov 16, 2010
accord trunk release ftw. i have it tied to my very old viper alarm. still works perfectly almost 10 yrs later.
Old Nov 24, 2010
kccivic's Avatar
kccivic is an unknown quantity at this point
What year Accords work for this?
Old Nov 24, 2010
get the 01 accord latch. it has the cool green opener that glows in the dark. in case you lock yourself in the trunk and cant figure out how to open the rear seats. also the 01 accord washer nozzles are a perfect fit if you want color matched instead of black.
Old Nov 26, 2010
kccivic's Avatar
From a quick internet search, I need to find one with two electrical connectors on an EX, not LX. Does coupe or sedan matter?
Old Nov 27, 2010
i dont think so, just be sure you ask for one that is "power" trunk release. they have manual for accord too, i thought it would be obvious you want the power one. check the diy forum if you need a part number for it.
Old Dec 23, 2010
kccivic's Avatar
Never-mind: I found my multimeter
Does anyone have a wiring diagram for the accord release?
Coming from junkyard pigtail:
Black/ brown : Ground
Black/ silver : Closed circuit when latch open (Trunk light)
White/ Red : 12+ for power latch open
Blue/ silver : Closed circuit when latch open (Trunk light)
Orange/ silver : Unknown
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
hayden55
Jul 8, 2015 11:38 PM
Bounddyy
Jul 8, 2015 11:22 AM
cgavin1
Jul 7, 2015 07:10 AM
carhag2000
Apr 25, 2015 01:33 PM
