Not sure what the problem is...
Old Sep 15, 2010
Crutcher's Avatar
Crutcher is an unknown quantity at this point
I drive an '02 EX. Couple weeks ago my battery light came on, then the car died. Found out the battery was bad, replaced it, and all has been well until yesterday when it came on again. Tested the battery, tested the alternator, and everything seems to be working fine, but the battery light is on again. I'm not sure if it's planning on dying again, but I'd rather not end up stranded. Any ideas on what to check next?
(All testing was done at Advanced Auto parts.)
Old Sep 15, 2010
MelJ's Avatar
Trance Addict
Re: Not sure what the problem is...
You sure the alternator is running? I was working on my Corolla and the belt I was trying to tighten slipped and wasn't spinning, therefore, no power from the alt. I thought the belt was on secure, but it wasn't. Battery light came on because it was running off of it. Tightened it a bit more and all was well. I mean, this could be something completely different though. I'm just going by what I experienced today.
Old Sep 15, 2010
battery light means there is a problem with the alternator (charging system). the light does not come on for a bad battery. make sure you get someone who knows how to do the alternator test. i used to work at advance auto and you really need to pay attention to the readouts. it can say the alternator tests good (diodes are fine, it produces voltage), but if you look at the actual amp reading, it may only be 40 amps instead of 70 and that will slowly drain the battery down. make sure you ask next time how many amps the alternator produces under load.
Civic4ever1996
Apr 16, 2015 08:30 PM
aZnVoYCe
Dec 23, 2001 09:56 PM
aZnVoYCe
Dec 23, 2001 12:39 PM
cable
Dec 17, 2001 06:14 PM
aZnVoYCe
Nov 11, 2001 10:43 PM
