Wiring a system
Old Aug 18, 2010
drew65's Avatar
drew65 is an unknown quantity at this point
Wiring a system
Im going to put a system, 2 12's and 1200 amp, into my 05 civic coupe soon and need some pointers... ive only run wires once, on an 85 mercedes, and it gave me hell!!! I need to know: the best way to run the wires, how to pop of the moldings, and the easiest way to do this... ive already installed an aftermarket stereo if that helps... i just got the car and its time for a little bit of thump... please help
Old Aug 18, 2010
Re: Wiring a system
for power, I ran mine straight from the battery, through a rubber grommet on firewall, passenger side of the center console, under the passenger side door sill, behind the rear passenger plastic part, and into the trunk. I ran the amp remote wire the same route. If you pull off the plastic bottom cover on the passenger side footwell and pull back the carpet, you can kinda see the grommet.
here's a view from the engine bay. Took this picture standing just forward of the battery, looking down into the engine bay. The grey shiny-ness at the top of the picture is my intake. That blue wire going through it is also just over ½" (it's 13.61mm, which is .53")
My speaker wires and RCA cables, I ran from the radio, underneath the center console, under the carpet, to the back driver side under the rear seat bottom cushion, and into the trunk from there, keeping wires carrying sound signals as separate from the power wires as humanly possible.
My knuckles didn't like me at all after routing the power wires. Lots of blood and skinned knuckles in cold, damp 40-50º weather made for lots of pain.. lol.
Follow this DIY guide to remove the rear plastic panels (and rear deck if installing speakers)
https://www.civicforums.com/forums/1...rear-deck.html
Since you installed an aftermarket headunit, you already know how to take the center console off
Old Aug 18, 2010
Mad Dog Tannen's Avatar
Re: Wiring a system
I ran RCA cables underneath drivers side doorsills and power+remote wires underneath passenger side sill. I did it right and R2'd panels on both sides. To do that I had to take out the rear seats to get underneath the panels in the side/rear. Most of the plastic just has little clips that pop right out and back in, maybe a couple screws and bolts that will be obvious. It was a pain in the dick but no exposed/rubbing wires. You have to run the power and RCA cables through different spots or you can get interference (humming and crap in the backround of your sound).
Old Aug 20, 2010
drew65's Avatar
Re: Wiring a system
thank you this is VERY helpful!!! and one more question if i replace the speakers... since the guide riceboy told me to go to says they are paper cone... do i plug that into the amp? or do i just connect it to the same wires as the old speaker was connected to?
Old Aug 20, 2010
drew65's Avatar
Re: Wiring a system
and if i have to wire it to the amp i have no idea where to connect it... kinda a newb when it comes to I.C.E. ... just started like last year
oh yeah and riceboy... you are crazy helpful!!! i was reading some other stuff tryin to get this figured out... and you had a comment on like every one!!! you are officially a G in my book!!!
Old Aug 20, 2010
Re: Wiring a system
Haha.. thanks. I've just been around these forums a long *** time, and I've been tinkering with my 2002 civic for the better part of the last 8 years. I kinda know what I'm talking about.
WaryDriver
23
Jul 22, 2015 07:18 PM
davidezerron
May 30, 2015 02:45 PM
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 18, 2015 07:37 PM
MamaBear2015
May 3, 2015 02:17 PM
