infinity kappas
Old Apr 20, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
infinity kappas
i have realized that a lot of you have pretty positive things to say about their speakers. i just found out the stock speakers on my LX sedan are so shietty that i wanna upgrade them. the thing is, i dont really wanna get a sub and i realize that the infiniti kappas all have very high low end frequencies such as 45HZ to 200MHZ. 45 is pretty high to be low end since pioneers and others have lows all the way down to 25 or so. will I be short of bass if i get the kappas without a sub?
Old Apr 20, 2002
WhiteRabbit's Avatar
the numbers are BS. most 10 inch woofers out there will crap out at above 40 Hz in a sealed box.
I have owned green kappa 6x9's before, they go decently low (WAY lower than a pioneer) they sound best off of deck power, however the new kappas i would guess are different.
if your looking to upgrade your factory speakers, that being the only change you want to make, then you cant beat infinity for sound quality. a pair of reference component speakers for teh front will have an exelent stage in your car while getting decently loud on your deck's power. For the rears, kappa 6x9 two ways will give you all teh response you need form the back and will sound crisp and go decently low.
if you later decide to upgrade your deck, your speakers will only perform better. by doubling your power they will sound bright and only get louder.
if you decide to get an amp, your speakers will be ready to take teh power, however, with 50 watts you will lose your low end unless you keep teh gains far down, and your reference components might get overly bright. but they can take the power if you decide you want more for your stereo.
infinity is the most reccommended speaker for mid level systems due to their great versatility, just like JBL or sony amplifiers.
Old Apr 20, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
I'm running 3-way Infinity Kappas all around. 6.5 up front 6x9 in the back. The rear speakers put out plenty bass...I was very impressed. I just ordered Kappa 10.3T tweeters for the front and at the same time adding a JBL amp. Geeze, WhiteRabbit hit the nail on the head as far as my setup. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 21, 2002
PESTLNC's Avatar
Oh, BTW...you'll need to do some metal cutting and use a spacer to install 6.5 Kappas up front.
Old Apr 21, 2002
mohawkboom's Avatar
Okay,,well if you want bass and no subs..you need an amp and Blaupunkt OdWA 6x9's in the rear.. i ran these for ashort period of time in my old Hyundai Sonata I had.. They have about the best Bass response you can get from 6X9's and they are Dual voice coil 6X9's. You can amp just the woofer for low frequency responce and play the midrange and tweets off your HU.,,Get Infinity Kappa 6.5's for the front.. Blaupunkt OdWA 6x9's for the rear (will not properly clear the magnets without modification however) and a nice 50Wrs x4 amp to power the fronts and rear woofers..run the rear mids off the HU......
Cheers
Mohawk
Old Apr 21, 2002
i already upgraded my receiver a while back. its time for me to take the next step and upgrade my stock speakers. as for the frequencies, why does infinity advertise the mas being so high?? it might give ppl the impresion that they deliver no bass. also, what other brands do u guys recommend cuz the inifinitis are quite expensive.
Old Apr 21, 2002
<< Okay,,well if you want bass and no subs..you need an amp and Blaupunkt OdWA 6x9's in the rear.. i ran these for ashort period of time in my old Hyundai Sonata I had.. They have about the best Bass response you can get from 6X9's and they are Dual voice coil 6X9's. You can amp just the woofer for low frequency responce and play the midrange and tweets off your HU.,,Get Infinity Kappa 6.5's for the front.. Blaupunkt OdWA 6x9's for the rear (will not properly clear the magnets without modification however) and a nice 50Wrs x4 amp to power the fronts and rear woofers..run the rear mids off the HU......
Cheers
Mohawk
of course. blaupunkt must be the best if YOU ran them =/
after all, your the god on this forum
Old Apr 21, 2002
mohawkboom's Avatar
they aren't the best..but they're pretty good..and they do give you alot more low end extension..about equal to that of kicker 8" Free air subs..and still offer some pretty clean midrange reinforcement for some rear fill.. and knock it off about me being some kinda god or any crap like that...
Cheers
Mohawl
Old Apr 21, 2002
what kind of real world low bass extension were you getting running them? i cant imagine any 6x9 keeping up with a half decent 8".....
edit: sorry about teh god remark, oh "12 volt Guru with the tunes" [IMG]i/expressions/laugh2.gif[/IMG]
dont worry about me, im just PMSing. soon ill bleed, and be civil again [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Apr 21, 2002
mohawkboom's Avatar
well they'll keep up with the free air 8's.. not that actual 8's that belong in enclosures[IMG]i/expressions/face-icon-small-smile.gif[/IMG].. both have about the same cone area.. about 2Sq.In difference..and the Blau ODWA's have 8mm Excursion over the Free airs 7 [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. so it kinda evens out..
Cheers
Mohawk
New Sig!!!
Old Apr 21, 2002
<< Well X-max is mostly a Mareting number unless you're into competition or like Really loud bass..in which case X-Max is one of 2 Factors that determine displacement which Displacement. and BL factor combines with power is what give your your Actual output [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. >>
i knew that "stump mohawk" thread would come in handy! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jun 23, 2002
dragoon's Avatar
Quote
[hr]Originally posted by: PESTLNC
Oh, BTW...you'll need to do some metal cutting and use a spacer to install 6.5 Kappas up front.[hr]
what size spacer is necessary for the 6.5 kappas on a coupe?
Old Jun 24, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
I've got infinity reference components up front, running off my nak deck. A little bright for my taste. i might have to go to some focals or something before i amp them, i dunno. also, bass isn't so great. mine at least are intended for use with a sub.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
dups
Jun 11, 2002 02:08 AM
civic510
Apr 29, 2002 11:23 PM
PESTLNC
Mar 14, 2002 09:19 PM
racinginindy
Jan 28, 2002 07:34 PM
