HID swap issue
Old Jun 21, 2010
Pestra01's Avatar
Pestra01 is an unknown quantity at this point
HID swap issue
I got a set of HID retrofits from a friend who never used them, i set it up in my 7th gen civic and now i have no low beams, the fuses under the hood seem to be fine not burnt but the headlight relays themselves are burning hot so i pulled them does anyone know if replacing them will fix the problem or should i get aftermarket ones with a better amperage rating?? help!
Old Jun 25, 2010
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: HID swap issue
When using a retrofit from someone who may be questionable, whether it's a friend or not, your best bet is test everything from a battery first. You also sound like you wired it directly to the factory harness which is a huge no no in any HID form. If you need help with wiring them correctly, ask, and as for the low beam/high beam issue, I take it that again, you used the factory wiring and the retros may not be wired correctly. More information is required, thanks.
Rogelio Rey
May 24, 2015 08:30 PM
jmdcivic
May 20, 2015 09:52 PM
McD
Apr 22, 2015 05:28 PM
Voiceofid
Feb 3, 2002 03:54 PM
supercivic01
26
Jan 26, 2002 10:11 AM
