fog light fuse?
Old Jun 20, 2010
M4n1aC's Avatar
M4n1aC is an unknown quantity at this point
fog light fuse?
Hey im having a problem with wiring for lights to my 2004 civic lx coupe.... Im pretty sure I have everything hooked up correctly, but I need to add a fuse for my fog lights. the problem is... there isn't a place for a fog light fuse under the dash, or under the hood... could someone give me a suggestion? thanks.
Old Jun 20, 2010
Re: fog light fuse?
http://www.handa-accessories.com/civic/04-civfogex.pdf
If you're using Honda OEM fog lights, this should work. The very bottom of the installation instructions tells you to hook the fog light harness into the under-dash fuse panel
Otherwise, if you're using the battery as the power source with a relay, go buy a 10A inline fuse assembly from a local auto parts store and wire it between the battery and the relay
Old Jun 20, 2010
M4n1aC's Avatar
Re: fog light fuse?
ok...there is no 6 pin slot in my fuse box...if we go the battery route, how wire it between the battery and the relay?
Old Jun 20, 2010
Re: fog light fuse?
do you want it so you can turn them on whenever? or only when at least the parking lights are on?
Old Jun 20, 2010
Re: fog light fuse?
in any case, here's how I'd imagine it'd be wired up, the red +12VDC wire being one of your choice: hot at all times, hot when ignition in "acc", or hot when the parking lights are on, or hot when the headlights are on.
the fuse being a piece that looks like this
Old Jun 21, 2010
M4n1aC's Avatar
Re: fog light fuse?
Ok i really appreciate the help. I just don't have a fuse like you pictured but maybe I can get one of my buddies over here that would actually make sense out of the diagram you posted... again, thanks a lot
Ma213802
May 18, 2015 07:01 AM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
