01-03 civic TYC projectors with hid wire diagram
Rep Power: 788 01-03 civic TYC projectors with hid wire diagram
i made this a while back for a member, so might as well post it up for others. this is only useful if you have hid lo beams (either retrofit or h1 hid kit) and the tyc halogen hi beams. the lo beams require a new harness to be constructed, but the hi beams can simply be plugged into the oem harness using the supplied tyc h4 connectors.
the diagram allows both lo and hi beam to be on at the same time.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
