2002 lx keyless entry question
Old Feb 22, 2010
stymes01's Avatar
stymes01 is an unknown quantity at this point
My girlfriend just got a 2002 civic LX. I want to install keyless entry and have done it with aftermarket systems in the past but wanted to know if anyone knew if there was an easy way to install factory system? I read all 6th gen lx and ex's had everything in place for keyless just not necessarily hooked up. Is this true for the 7th gen? If not any recommendations? Thanks.
Old Feb 22, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: 2002 lx keyless entry question
I know my 02 LX had keyless entry from the factory so you might only need the remotes...
Old Feb 23, 2010
electric130's Avatar
i looked at doing it and the cost wasn't justifiable compared to an aftermarket alarm system. the OEM keyless was going to be about $200 in parts (remotes may have been more, can't remember) and then it was $50-100 to program everything at the dealer even if you installed yourself. to go to OEM alarm was going to be around $400 for parts and programming. i went with a Viper alarm and paid $200 installed so now i have keyless and an alarm. the harnesses are already there on LX and EX, but parts, installation, and programming make the OEM system impractical compared to aftermarket for me.
Old Feb 23, 2010
CraigW's Avatar
I got one of the keyless only systems from Crutchfield around $65. Had a good range and worked well. You can access the lock/unlock wires at the drivers side kick panel. Since you have power locks it is pretty simple.
manfredww1
Jul 14, 2015 10:24 AM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
fatih717171
Jul 8, 2015 12:14 AM
