Power window problem
Old Feb 15, 2010
hondadad91's Avatar
hondadad91 is an unknown quantity at this point
My daughter has a Honda Civic 2001,the rear window on driver side went down,but won't come up.I took the door panel off unplugged the switch and manipulated it to see if it would go up and it does.So i assume the motor and reg or good.Don't know what to check next?Thanks in advance.HD
Old Feb 15, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: Power window problem
I am a little confused, first off it is a 4 door right? what did you manipulate to make it go up?
Old Feb 16, 2010
CraigW's Avatar
They way those CHEAP regulator/motor assemblies are made on the 7th gens you would most likely have to apply voltage to the motor leads directly (which is a good testing method btw)
If the motor is getting power you may be able to assist it back up.
The master switch can cause strange problems as well.
Old Feb 16, 2010
electric130's Avatar
make sure the child lock isn't turned on.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
