Keyless entry not working -2003 coupe
Old Feb 1, 2010
Rob121's Avatar
Rob121 is an unknown quantity at this point
Hey, I have a question. My aftermarket stereo stopped working the other day. now my key less entry doesn't work in my car. I was wondering if the key less entry works through the head unit? The key less entry is stock if that makes any difference.
Old Feb 2, 2010
CraigW's Avatar
Re: Keyless entry not working -2003 coupe
Not controlled through the head unit on this generation.
Check the 'Back Up" fuse in the under hood fuse box.
Old Feb 2, 2010
Rob121's Avatar
Thanks, will check when I'm home. I checked the radio/accessory fuse and it was fine, I didn't realize there was a fuse under the hood for it.
Old Feb 2, 2010
CraigW's Avatar
It's the fuse that supplies constant power to the radio for memory, it also supplies keyless reciever.
Old Feb 2, 2010
Rob121's Avatar
changed the back up fuse, works perfect. thanks for the help
Shabba
May 13, 2015 10:55 PM
usajags84
May 10, 2015 08:11 AM
ORskier
May 3, 2015 12:54 PM
darwin-t
Apr 18, 2015 09:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
