Weird Headlight Problem
Old Dec 30, 2009
craddock1's Avatar
craddock1 is an unknown quantity at this point
I have a 2004 Civic Hybrid, and the right headlight has gone out on it. I replaced the bulb, and it didn't work. I then replaced the headlight fuse, and it still doesn't work. I'm not sure what else to try. I've done an Internet search and I've heard people suggest "checking the ground" or "replacing the headlight switch," but I'm not sure how you check the ground on just one headlight, and I've never heard of replacing a headlight switch. Anyone out there have any suggestions?
Thanks!
Old Dec 30, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Weird Headlight Problem
Maybe the replacement bulb was defective?? Or someone dropped it.
Old Dec 30, 2009
certain civics have a recall for the headlight switch going bad when a wire burns out. the grounds for the headlight harness are behind the front bumper on the two sides. its possible one of them is corroded.
Old Dec 31, 2009
CraigW's Avatar
umm, well the recall was for 01s and some early 02s.
Grounding is provided through the headlight switch for the high beams and the low beam is directly grounded. ( for the 2 bulb per side systems)
You could have an open connection at the socket. You could test by gently moving the wires near connector and headlight connector itself to see if the light flickers or tries to work (don't break bulb)
stryder12
Jun 30, 2015 08:33 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
tylerginevan
Apr 27, 2015 12:29 PM
shaejb15
Apr 26, 2015 07:44 PM
