Safest current draw off battery for sub amps?
Old Feb 27, 2009
phil6006's Avatar
phil6006 is an unknown quantity at this point
Question Safest current draw off battery for sub amps?
I'm looking to add in either one or two 8" Subs, but I was looking around the ELD thread and I was wondering what do you guys think would be a safe current draw off the battery without dropping the voltage below 12.5 or so, because I don't want to change the alternator yet. I couldn't really find anything in a search.
I'm not looking for anything big, I was planning on using an Audiobahn Dub1002 amp bridged, which probably pulls around 13-18 amps (20 amp fuse), which would be 220wRMS/440wPeak bridged at 4Ohm.
I don't know how much the rest of the car draws (lights, heater fan, wipers, defogger, etc). I have a 2F Capacitor also that I was going to plan to hook up, which should help somewhat, but I want to see you all think.
I have the capability to install and test it out, but I don't want to buy the speakers and build a box if it isn't going to work properly.
Is there anyone out there who is running the stock alternator with around a 200-400w amp without problems? Or is there a certain way to hook it up to the detector the right way or through a fuse point?
-Phil
edit: probably would go with one Infinity Reference 850W in a ported box.
http://manuals.harman.com/INF/CAR/Bo...eters/850W.pdf
Old Feb 27, 2009
sl33pyriceboi's Avatar
Re: Safest current draw off battery for sub amps?
just run a 4 or 2 awg wire through a AGU fuse then to the battery. u should be fine when ur setup. when ur engine is on, it'll go above 12v (most likely 13-14v)
Old Feb 27, 2009
Clean 03's Avatar
Clean 03 will become famous soon enough
I agree. You will be fine with the stock battery and alt. 2-300 watts rms isnt that much power. Im running 300 watts rms with stock battery and alt and its fine.
Old Feb 27, 2009
BigVic4545's Avatar
BigVic4545 is an unknown quantity at this point
you have nothing to worry about buddy....im running a 12" kicker l7 and a 750 watt kicker amp and a 200 watt alpine amp on stock battery and alternator...my lights do not dim at all, and im having no power issues.. Just make sure to use at least 4awg wire. And do not waste money on caps...they r worthless most of the times.
Old Feb 27, 2009
phil6006's Avatar
ok cool. I would think it would be able to run an Audiobahn A8000T mono amp? This is my actually sub amp I used to run in my truck. At 2 Ohm it is 800W RMS, but 4Ohm its 400W RMS, which is what I would run it at.
Old Feb 27, 2009
i am runing a 4channel 600w infinity ref. amp to power my kappas. they are fine as well.
Old Feb 27, 2009
BigVic4545's Avatar
I think that as long as ur system doesnt draw more than 40-60 amps u should be good with stock electricity. I wouldnt go over 800 watts rms of total power on stock power. Just look at the fuses on the amps and add the total...dont go over 40-60 amps on stock battery/alt.
Old Feb 27, 2009
but seriously, even with my 600w, i dont even turn it half way.
i can hear my car, windows rolled up, from inside my house with half way.
Old Mar 16, 2009
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
im using an 80amp fuse block on my audio system, the amp it self has a built in 60amp fuse so yeah and a 4awg cable running to the trunk
jzhartman
22
Jul 23, 2015 10:42 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
