power control wire
Old Feb 25, 2009
Mike123's Avatar
Mike123 is an unknown quantity at this point
power control wire
does anyone know what color wire i should hook up the power control wire to for my amp from the back of the HU? Its a 2005 civic ex special edition so it has the upgraded radio which doesnt use the same wire harness as the non special edition
Old Feb 25, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: power control wire
it doesnt matter really. just any power source that will have current when you want your amp to turn on. you can just loop your remote wire to a fuse in the fuse box that is on when your car is on. or you can wire it to the cig lighter. just giving you some options.
Old Feb 25, 2009
DDragon7's Avatar
And if your going to do that, easiest is to get the power from the lighter socket.
Old Feb 26, 2009
Mike123's Avatar
okay. sounds good, can i just splice the positive wire going to the cig lighter or should i loop it threw a fuse? or either one?
Old Feb 26, 2009
DDragon7's Avatar
I think its best to loop it through a fuse, just in case something happens.
Old Apr 21, 2010
Orcus332's Avatar
Orcus332 is an unknown quantity at this point
I'm going to revive this thread for continuity instead of starting a new one. I have the same question. Have a stock HU in a 2005 EX SE and going to hook an amp up to it. Need a remote wire to power the amp. I'm not entirely sure what it means to "loop it through the fuse." Could someone explain that, or tell me how to hook it up to the accessory port (don't have a cigarrette lighter, just the port that can be used to charge cell phones etc).
Thanks!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
SSMatey
Apr 13, 2015 06:09 PM
