i need your trunk pics
Old Feb 14, 2009
juvehab's Avatar
juvehab is an unknown quantity at this point
installing a system post pics of your truck looking for amp location ideas where i can still use the folding rear seats
Thanks
Old Feb 14, 2009
Re: i need your trunk pics
heh you might need all day to read every post.
https://www.civicforums.com/forums/2...r-systems.html
https://www.civicforums.com/forums/2...r-part-ii.html
https://www.civicforums.com/forums/2...et-up-new.html
https://www.civicforums.com/forums/2...-whatever.html
Old Feb 15, 2009
Honda05's Avatar
Honda05 is just really niceHonda05 is just really niceHonda05 is just really niceHonda05 is just really nice
Heres my old setup
Old Feb 15, 2009
electric130's Avatar
search function is your friend!
Old Feb 16, 2009
skipbarber's Avatar
i just slid a board of MDF under the back seat cover and secured my amp to the folding seat. works great.
Old Feb 16, 2009
sl33pyriceboi's Avatar
more like:
"the search function owns you"
Old Feb 18, 2009
lowlife9's Avatar
Exclamation Re: i need your trunk pics
took me awhile to get the rite fit i also shaved some plastic but flipdown still function properly
Old Feb 18, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I'll post pictures later but I took out the entire floor of the trunk and put down a piece of plywood in its place. Then cut a hole in the center of it to get at the spare tire and mount 2 amplifiers and the computer on the perimeter of the plywood. Then lay pieces of 2x4 around the floor to create a suspension for the next layer. Get a second piece of plywood, carpet it and lay it over top of everything so that you have a flat floor, carpeted, with all your electronics underneath. Then make the center removable with a handle so you can still get at the spare through both floors.
Old Feb 18, 2009
this is what i did, except i did a thumb-hole by the trunk latch instead of a handle and i put the hinges inside the fold so only a little bit is visible. it's worked awesome and i've had hundreds of lbs of weight on it many times.
https://www.civicforums.com/forums/2...pare-tire.html
ricer_em2
May 11, 2016 08:09 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
thatcham
Sep 30, 2015 08:28 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
