Power lock fuse problem
Old Jan 20, 2009
jsiu85's Avatar
jsiu85 is an unknown quantity at this point
Hey everyone,
Recently, my power locks weren't working and found out that the power lock fuse was broken in the fuse box under the hood. I replaced the fuse with one of the spare 20amp ones and the power locks worked again. I tested it a few times to make sure but the fuse broke again. I replaced the fuse again but this time using one of the 30amp ones which lasted for a few days but now the fuse broke again. I'm assuming there is some electrical problem that is causing the fuse to break but I wouldn't know where to start to check. Does anyone have any ideas???
Thanks!
Old Jan 20, 2009
CraigW's Avatar
Re: Power lock fuse problem
Don't use larger fuses.
Need more car info.
Any of the locks seem tight when worked manual ?? Do they move up and down quick or slow ??
Old Jan 20, 2009
jsiu85's Avatar
Hey Craigw,
I own a '02 acural el, equivalent to a civic sedan. The locks don't seem that tight at all but then again it's not loose. Would having tight locks cause the fuse to pop??
Old Jan 20, 2009
CraigW's Avatar
Could be a tough one. Not sure if a bind would cause the fuse to open or not.
Do they move up and down quickly ??
What # fuse in which box are you replacing ??
Old Jan 20, 2009
electric130's Avatar
exactly!!!! doing this is just begging to create an electrical fire. fuses are sized based on the wire size. putting a larger fuse in will allow more current to flow through the wire than it can handle. it will get hot and possibly catch fire. fuses are there to protect the system when there's a problem. if the fuse blew, you have a problem. if it blew multiple times, then you definitely have a problem. for a fuse to blow, power has to get shorted to ground. so somewhere, you have a wire or component that is shorting out. i know that's probably not much help, but i wanted to get the fuse safety tid bit in there.
Old Jan 21, 2009
jsiu85's Avatar
Thanks electric130... From now on I will use the correct fuse! I guess I'm gonna have to look around to see if any wiring is loose or disconnected somewhere.
I am replacing #16 (20A) fuse which is the power lock fuse described in the manual.
Old Jan 21, 2009
CraigW's Avatar
#16 in the under hood box has constant power and runs into the multiplex unit located inside the under dash fuse box, At first glance it appears to be the source for the actuators supply. I will post up the theory when I can get to the electrical manual, it may have some details.
There is no theory section for the system in my electrical manual (some pages are missing from the scans)
I would install the fuse back in and avoid using the keyless/power locks to see if it still opens.
Old Feb 22, 2011
BillaBonger22's Avatar
BillaBonger22 is an unknown quantity at this point
Hi, i have a 2002 Civic DX 4dr My Cd player has been acting weird (not reading CD when cold) So I decided to give it a gentle tap now the power to my CD player is gone and strangely enough at the same time my Power locks are not working with my keyless entry remote. I have checked the fuse under the steering wheel for my CD player and it is not blown. Any suggestions? I have been searching the web for hours and can't seem to find any.
Thanks.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
darwin-t
Apr 18, 2015 09:29 PM
SSMatey
Apr 13, 2015 06:09 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
