Half of rear defroster not working?
Old Jan 14, 2009
shri_nadk's Avatar
shri_nadk is an unknown quantity at this point
Hi,
I just got a 2004 civic and the top 2-3 bars of the rear defroster(which has the antenna) is not working. Only the bottom part is working. The mechanic told me that it never works and that part is only the antenna.
Is that true or is he just saying it so that he doesnt have to fix it in the warranty?
Thanks for yor help,
Shri
Old Jan 14, 2009
Re: Half of rear defroster not working?
um the antenna is the straight line that goes down vertical thru the middle. now you can trace to see what else its connected to, just follow the lines. i dont use my defrost enough to know how many lines it uses. but trace them all, see which ones are connected to the antenna or the power feeds on each side. it may just have a small break in the line thats causing part of it not to work.
Old Jan 14, 2009
CraigW's Avatar
My sedan has 12 grid lines. I would have to say the top 1/3 of the glass is not heated.
Old Jan 14, 2009
electric130's Avatar
that's the antenna
Old Jan 14, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Whenever I turn on my defrost I notice every horizontal line melting snow/ice. I haven't noticed any blank spots.
Old Jan 14, 2009
04 Honda Civic's Avatar
all the way on the top of mine doesn't defrost either, I think that's just how it is
Old Jan 15, 2009
if you guys go look at your cars, find the big spot where the defrost power connects to the window. follow it up the side of the window until it turns in towards the middle. that's where the defrost ends. the rest of the window (6" or so) on up to the top, those wires are your radio antenna. they are not designed to defrost your window, and therefore, they won't.
jc33312
May 12, 2015 03:17 PM
Pudnite
May 9, 2015 07:51 PM
ORskier
May 3, 2015 12:54 PM
superstanko
Apr 28, 2015 04:38 AM
Pir8pete
165
Mar 6, 2009 05:16 PM
