dome/ceiling light failed on 2005 civic
Old Dec 17, 2008
podfish's Avatar
podfish is an unknown quantity at this point
There seems to be some kind of brains behind these lights (they turn on when I turn the key to off, and slowly dim, for example) so I don't think it's just a simple doorswitch-battery-light circuit. The fuse panel diagram doesn't specify one fuse for the lights.
This is just a prep question, since I haven't started poking around with a voltmeter yet... but is there some specific place I should start looking? The bulb looks ok - the filament looks complete - but I'll of course test it for continuity too.
Old Dec 17, 2008
CraigW's Avatar
Re: dome/ceiling light failed on 2005 civic
It is controlled by a circuit inside the under dash fuse box called the "multiplex control unit"
The bulb is provided power and is controlled by the system. Fuse #10 7.5 Amp in under dash box, Fuse #3 7.5 Amp in under hood box.
WHT/BLU = Constant 12 Volts
GRN/RED = Control Lead
CarStuff
Dec 6, 2020 12:52 PM
twtron
Apr 17, 2015 12:09 AM
dano2005
Apr 14, 2015 01:58 AM
gabrown2
Apr 11, 2015 08:22 PM
cazminn
Nov 9, 2001 11:18 AM
