help w/ heater
Old Dec 13, 2008
pHiStAhH's Avatar
pHiStAhH is an unknown quantity at this point
Question help w/ heater
i just installed my headunit n sub/amp today
but as i was driving i tried to turn on my heater
the thing doesn't even work anymore!
lights work but no heat blowing from vents
need help asap
Old Dec 14, 2008
electric130's Avatar
Re: help w/ heater
take the bezel off and make sure all the connectors are on all the way on the controls.
Old Dec 14, 2008
pHiStAhH's Avatar
Re: help w/ heater
yeahh i tried that but still no air flow no matter what
i turned the ac/heat **** n i can hear a slight noise
but still no affect from the air level ****
i ran my power wire through the passenger firewall
could of i nipped a wire or something?
Old Dec 14, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: help w/ heater
always check the fuses first. 1/2 the time its always a random fuse that blows.
Old Dec 14, 2008
pHiStAhH's Avatar
Re: help w/ heater
well I checked the fuses under the hood
it was fine
anywhere else I should check
Old Dec 14, 2008
K/Turbo's Avatar
Also known as rlmedin1.
K/Turbo will become famous soon enoughK/Turbo will become famous soon enough
Re: help w/ heater
it was fine
Yes, the dashboard panel under your steering wheel has two *****. Turn the two ***** to release this panel. You should see another fuse box there towards the right.
Old Dec 14, 2008
nastasi980's Avatar
nastasi980 is an unknown quantity at this point
Re: help w/ heater
sounds like to me the fan motor went . it happen to mine over the summer .checkd my fuses they were fine .i turn the **** but no air my fan motor went cost a 100 to get fixd
Old Dec 14, 2008
pHiStAhH's Avatar
Re: help w/ heater
i checked the fuses and i think they're fine
there's one called heat motor and another heat one: a 40 and 20a fuse fine
any other solution u got for me?
Old Dec 15, 2008
pHiStAhH's Avatar
Re: help w/ heater
any suggestions please?
its 30 degrees in CO and its my lil sister's car
cant have her go to school with no heat
Old Dec 15, 2008
CraigW's Avatar
Re: help w/ heater
Listen near the under-hood fuse box engine off, key at position II While someone turns the fan switch on and off several times. You should hear a click from the blower relay (it is the larger metal case one)
Go back over all your work and look over the area. Look around where you went through firewall. Check wiring and connector on the blower fan transistor mounted on the ducting.
I'm assuming the blower fan is inop ??
Old Dec 15, 2008
pHiStAhH's Avatar
Re: help w/ heater
can u tell me where the blower fan transistor is?
sorry im a newb on cars
Old Dec 15, 2008
CraigW's Avatar
Re: help w/ heater
https://www.civicforums.com/forums/3...t-working.html
This thread has some pictures.
Old Dec 15, 2008
pHiStAhH's Avatar
Re: help w/ heater
thanks man
i'll try it out after i get off work
hopefully i dont have to do anything too big to fix the problem
Old Dec 15, 2008
pHiStAhH's Avatar
Re: help w/ heater
if there's any other suggestions please let me know
Old Dec 16, 2008
pHiStAhH's Avatar
Re: help w/ heater
ahhhh i fixed the problem
my dumbass somehow knicked off a wire through the firewall
damn it!
just taped it up for now and soldering it this weekend
thanks for everyone's help though much appreciated
o0o and if anyone knows anyone who's selling 04/05 tail lights gimme a heads up
h4ldol
Apr 24, 2017 08:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
cferry7
Oct 3, 2015 04:33 PM
hatch90
Sep 3, 2015 08:45 AM
horta1212
Aug 22, 2015 08:31 PM
