Dual pro beam angel eyes with hid
Old Oct 28, 2008
gowen's Avatar
gowen should not be trustedgowen should not be trusted
Just bought dual pro beam lights with angel eyes and a HID kit. I would like some help with the wiring. Here is what I'd like to do but not sure if it is possible.
1. Have the angel eyes come on with the DRL
2. Have the DRL and angel eyes turn off when the HID is turned on
3. Have the HID and angel eyes turn off if and when I use the high beam
Basically I'd like it to work pretty much like stock. Is it possible to split the harness (going from a single housing H4 to dual housing H3 one HID one halogen which would be my DRL and high beam)
Thanks for the help
Cheers
Old Oct 28, 2008
sl33pyriceboi's Avatar
Re: Dual pro beam angel eyes with hid
yea its possible.
Old Oct 28, 2008
take a look at my thread. its all if not almsot all you'll need to do wt u want.
https://www.civicforums.com/forums/1...e-lowbeam.html
Old Oct 28, 2008
actually, it would be nice if you gave us what car ur driving... like year, model...etc
cuz 01-03 civic headlighting systems are different than the 04-05 than 06+
Old Oct 28, 2008
gowen's Avatar
03 civic 4dr
Old Oct 28, 2008
gowen's Avatar
I'm going to try to clarify a bit better what I want to do.
When car turns on:
Inner lamps (halogen DRL) lamps come on angel eyes come.
Turn switch to parking lamp setting:
DRL stay on angel eyes stay on parking lamps turn on
Turn switch to headlight:
Outter lamp (HID) lamps turn on inner lamps (halogen DRL) turn off angel eyes turn off parking lamps stay on
Push stick forward (high beams)
Inner lamp turns on (Halogen high beam) Outter lamp (HID) turns off angel eyes stay off parking lamps stay on
Am I correct that the inner lamp (H3 halogen) runs at 30% for DRL and full with high beam? (similar to the way a H4 works)
I would like it to work like a stock H4 but with 2 H3 bulbs instead of one H4
Hopefully this is a little more clear
Cheers
Old Oct 28, 2008
okay some problems of doing that. first, angel rings are very dim, barely qualifies as a park light so it wont be visible at all during the day. second, the leds that light it are terrible quality and are often wired wrong so they burn out in a few months. the drl works at 50% power because in DRL mode, they are connected in series.
basically the wiring could have been easy if you wanted the halos on with park light and off with headlight. the drl complicates things because the drl power wire will only be at 6v. the leds of the angel ring need around 12v. so to be honest, i dont see this working or being practical. you can always put the angel ring leds on a separate switch and turn it on whenever you want.
Old Oct 28, 2008
supafil25's Avatar
supafil25 will become famous soon enough
you would need a relay of some kind to turn them on and off when you turn on your low beams and high beams.
Old Oct 28, 2008
gowen's Avatar
I can live with the halos coming on with the park lights.
How about this,
Car turns on
inners on (halogen)
Park lamp setting
halos come on inner stays on
Head lamp setting
Outter comes on (HID) inner off halos off park lights on
doable??
Thanks
Old Oct 28, 2008
to make the halo come on with park light but turn off with main headlight, all you do is attach the halo power wire to the parking light power wire, then attach the halo ground to the 12v headlight power wire. the 12v wire is the one that becomes hot when the lo beam is used. this way, the halo will come on with park light because it gets power from park light wire, and ground thru the 12v headlight wire (when its off). but when you turn headlight on, the 12v becomes power and then the halo has both wires getting power, so it will shut off. same way i had mine hooked so they only stay on with park light.
Old Oct 28, 2008
gowen's Avatar
Thanks for the help with the halos!! Can you shed some light on the rest of the install? This is my daily driver and I don't want to f@$k it up
Old Oct 28, 2008
basically, bumper comes off, then the hardware holding the light on. theres two bolts on top, one on the side, and one kinda underneath you need a socket extension to reach. once its out, the new light should be plug and play into your stock headlight connector. usually the same turn and park sockets are used as well. you will need to aim the main projectors, and to do this the headlight has to be off the car so you can turn the bolt in the back of the housing. be ready to install it and then take it out a few times until the aim is just right. the lower cutoff line should be 2 inch lower than the height of your headlights at 25 ft away. simply means 2 inch downward slope of the light beam at 25ft away. so you dont blind people.
Old Oct 28, 2008
gowen's Avatar
Thanks Bud...going to try and do it in the next couple days...pics to follow
Cheers
Old Jan 13, 2009
rskaria's Avatar
rskaria is an unknown quantity at this point
How about this,
Car turns on
inners on (halogen)
Park lamp setting
Head lamp setting
doable??
Thanks
Hi i just bought my first civic the other day, i really like the halos eyes and i want this setup, would this work on a 05 civic lx sedan? or is the wiring different?
Old Jan 14, 2009
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
should make it so when you have your hi beams on, your low beams(hid's) stay on as well. turning hids off and on quickly is bad for them or so ive heard
Old Jan 14, 2009
read the 3rd post.
UltraHDGames
Jun 8, 2016 05:16 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
