dash lights
Old Sep 11, 2008
airman09's Avatar
airman09 is an unknown quantity at this point
dash lights
alright so i just put an amp and subs in and while my friend was helpin me hide some wiring a washer some how went into the power cord goin to my amp and blew my fuse on the power cord but ever since i replaced it, my gauges dont light up. any ideas?
Old Sep 11, 2008
CraigW's Avatar
Re: dash lights
"small lamps" fuse in under hood fuse box ??
Old Sep 11, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: dash lights
Did you check the fuses under the dash or under the hood? Double check both and hope the bulbs didnt burn out.
Old Sep 11, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
Re: dash lights
^^ agreed. it probably wasn't the only fuse that blew....
Old Sep 11, 2008
RallyeRedRider's Avatar
RallyeRedRider has a little shameless behaviour in the past
Re: dash lights
Disconnect the battery next time your playing with wires
Old Sep 11, 2008
Re: dash lights
way to go, you've made 2 posts so far, and they are both identical
:r epost::rep ost:
Old Sep 12, 2008
airman09's Avatar
Re: dash lights
thanks craig, yea as i was comin home from a party i got pulled over for it lol but yea why is it called small light fuse?
Old Sep 12, 2008
electric130's Avatar
Re: dash lights
deleted the other thread. don't start multiple threads in different forums with the same exact post.
Old Sep 12, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
Re: dash lights
Your illumination wires (orange wires) are probably hanging out, causing a short. Cap those wires, replace the small lamp fuse and you should be good.
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
antidote11
Dec 8, 2001 09:32 PM
