Sun/Moon Roof Button Light
Old Jun 29, 2008
qijian's Avatar
i have a 01 ex and on the left side where the cruise control button is at theres the buttons for the moonroof. i was wondering is there a light that lites the buttons up? because my parents accord has it. So im wondering if theres a light or fuse i can check to see if it went out. Thanks
Old Jun 29, 2008
FROSTY90's Avatar
FROSTY90 is an unknown quantity at this point
Re: Sun/Moon Roof Button Light
Mines Dont Light Up Either. I Thought That Was Normal
Old Jun 29, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
yes all those buttons light up. i relaced mine with white LED's so i never have to buy another bulb again
Old Jun 29, 2008
i just unplugged mine lol. its distracting having lit up crap down there. if you want the bulb lemme know, i have a whole bag of those stupid things.
^leds only last forever if theyre wired right. having a single led with resistor will not last forever. where do you think the other 10v goes? it has to be dissipated by the resistor which will eventually fail, and then the led will blow.
Old Jun 29, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Mine used to light up. I played with them, decided I didn't like it, then just took them out. Cruise is the only one that lights up, the mirror was too much of a hassle to put back together once I took out the LED that was in there and started playing with it.
Old Jun 30, 2008
D5cIvIc's Avatar
coming from a person who puts brighter lights in every single other aspect of his car. I find this comment ironic...
Old Jun 30, 2008
qijian's Avatar
so... is there a fuse to check to see if it gone bad? or is it for sure that only the bulb went out?
Old Jun 30, 2008
CraigW's Avatar
You should just need a bulb, The easiest is get the original assembly they have the mounting base already attached. Twist to left for removal, right to install bulb.
Old Jun 30, 2008
open the coin tray, and look for a star screw somewhere inside near the top. take that off, then the whole panel pulls out. the switch can squeeze out from the front by slipping it out. then you can see the bulb on the side, just use a screwdriver to twist it loose and then pop it off. its almost always the bulb, those lil things dont last too long cause they get hot.
Old Jul 1, 2008
qijian's Avatar
oh alright, will do when i get the time. thanks!
Old Jul 1, 2008
johnbt23's Avatar
yeah, mine has been burnt out for 2 yrs already. it doesn't bug me though. but im gonna change it sometime soon.
Old Jul 1, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
i've been having a similar problem. is there a fuse i can look for? one day it will be lit up and the next it won't be. it's like something is shaking loose.
Old Jul 1, 2008
CraigW's Avatar
I think the socket connections will cause the bulbs to come and go. A couple of my bulbs in the stereo pod after removal/replacement won't light without some help ( a slight bump with a fist)
You could try removing the bulb and gently scrape the 2 exposed wire leads to clean them and re-install bulb. It may solve it for you without buying bulb.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
dinsum
May 28, 2015 09:30 PM
Linda0818
Apr 23, 2015 11:30 AM
SSMatey
Apr 13, 2015 06:09 PM
fordfocussucks
Nov 6, 2001 03:16 PM
