Civic 2003 HeadUnit Problems!
Old Mar 25, 2008
kinono's Avatar
kinono is an unknown quantity at this point
hi everyone
i recently tried installing a head unit into my honda civic 2003!
but i couldn't get hold of a harness so i was told to hard wire it, cut the head of and just solder the new wires on. But when i did this, it never worked, the unit turned on and made a buzzing noise, like the CD reading noise but nothing else happened. After this i noticed the central locking was no longer working... so at the end i reinstalled the old plug back by just soldering the wires back together (same color), but the old head unit doesnt even work.
so now the new head unit and the old one + central locking is not working in the car
has anyone got some tips? on what i should do
thanks for the help
Old Mar 25, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Civic 2003 HeadUnit Problems!
check your ground!
Old Mar 25, 2008
sicklycivic's Avatar
sicklycivic is an unknown quantity at this point
also, Fuses? Sounds like you could have miswired the power and memory backup leads ???
Old Mar 26, 2008
Envy's Avatar
Diamond Member
it actually is very possibly a fuse. after re-reading the problem, i now doubt its the ground. but its still a possibility. you may have ****ed up your car by cutting the harness. in some cars, the central locking is in the factory alarm-equippedd headunit. if your car has it, you probably set it off or something. check all fuses and good luck. im not particulary knowlegedable about this, if you cant tell.
Old Mar 26, 2008
kinono's Avatar
hi everyone! thanks for the really quick reply's really appreciate it!
i will check the fueses, but which ones do i check, i know the fuse box is under the steering wheel, but regarding to checking if they are blown or not how would i know? thanks a lot
Old Mar 29, 2008
kinono's Avatar
hi~ is anyone there?
iv checked the fuese's in the pannel under the steering wheel, as well as the ones in the engin. However none of them are blown~
has anyone got any advise on what i should do now?
thanks a lot!
Old Mar 29, 2008
CraigW's Avatar
"back up" fuse in under hood box ??
Take switched and constant power connections loose from headunit.
Old Mar 29, 2008
kinono's Avatar
thanks for the quick reply CraigW, but could you please clarrify what you mean? im a bit lost sorry!
Old Mar 29, 2008
CraigW's Avatar
The #9 10 Amp fuse in the under-hood fuse box is named "back up" (it is for some items that require constant power)
On your headunit wiring in most cases the constant +12 Volt is the yellow wire and the switched +12 Volts is the red wire ( the headunits wires not the cars wires)
Check the fuse and check these connections that you made when installing.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
dooner24
Apr 14, 2015 07:51 PM
