0 Gauge From Alt
Old Mar 15, 2008
BoboP4C800's Avatar
BoboP4C800 is an unknown quantity at this point
0 Gauge From Alt
I've been searching the forums and would using 0 gauge from the HO alternator (170amp) to the battery cause too much resistance or would four gauge be perfectly fine.
Thanks
Old Mar 15, 2008
Re: 0 Gauge From Alt
ive heard its not good to use thicker than 4 gauge.
Old Mar 15, 2008
BoboP4C800's Avatar
Yea that's what read as well, I guess I'm just curious as to why anything larger could be a problem.
Old Mar 30, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
In theory, larger gauge (with all other things equal) can only lower resistance.
Old Mar 30, 2008
pheaton's Avatar
A descendant of 2k1civic.com
0 Gauge is a little silly for that I think.
Old Mar 30, 2008
electric130's Avatar
yep. i don't remember the equations from physics, but basically envision the wire as a pipe with water. you're going to have friction at the edges where the water is rubbing against the pipe walls. that equates to resistance in electrical terms. the bigger the pipe, the less friction in the center of the pipe. so the bigger the wire, the less resistance to current flow, the less heat build up, and the higher the amp capacity.
Old Mar 30, 2008
Old Mar 30, 2008
yep, that's it. so the bigger the cross-sectional area, the lower your resistance. of course, this assumes all other things equal as you said. if you compare premium 4ga to cheap 0/1ga, you may have a high resistance on the 0/1 due to cheap design.
Old Mar 30, 2008
Specifically the p (actually lowercase greek letter Rho) would be different for different materials. This term stands for resistivity which is a kind of molecular resistance for a given material.
So yes, a wire with more area could have higher resistance than a smaller area wire if the larger wire's resistivity is considerably bigger than the cross-sectional area difference between the two.
Old Mar 30, 2008
i think that's the problem. people think that all power wire is created equal. so they see JL Audio power wire's cost at 4ga and think the cheap no-name 0/1 for the same price and think the 0/1 must be better since it's bigger.......
Old Apr 2, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
4 gauge ok with a 2000W max @ 1200 RMS....
for one sub, and a 2 farad cap....
is my alt and bat going to be okay???
sorry to thread jack, i was just going to make another thread about 4 gauge wire
Old Apr 2, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ well if your alt is stock it will def fry out in no time. i am running a jl 1000/1 with a jl w7 and my stock alt blew out in a week of hardcore bumpin bass and my amp only pushes out 1000 rms compared to your 1200 rms. you need to upgrade the alt, if you have done that already everything should be good. 4ga is fine as well; i am running 4ga on my system too as recommended by JL.
Old Apr 2, 2008
02BLKCIVIC's Avatar
thanks
for sure new alt hu
Old Apr 2, 2008
02BLKCIVIC's Avatar
thanks
for sure new alt hu
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
