Looking for ideas on trunk setup
Old Feb 28, 2008
andyman97's Avatar
Turbo Guru
I have an Eclipse 12 and a fosgate power t4004 and am looking for some nice, clean, simple, neat ideas for a custom trunk setup. I have the material and colors already picked out, it will be black and grey. I'm up for any other ideas....
Old Feb 28, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: Looking for ideas on trunk setup
drop the sub into the floor with the amp in a false floor setup or build a wall in the back. nice and clean, and you still have functional trunk space
Old Feb 28, 2008
do something like Derek with floor mounted sub and amp. you could do it in a line in the middle with sub on top and amp on bottom.
Old Feb 28, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
^ i like that idea. it would definitely be a clean looking trunk.
Old Feb 28, 2008
04[ivi['s Avatar
New Member
04[ivi[ is an unknown quantity at this point
I say wall off your trunk man. Thats what i ended up doing and am quite happy with the outcome.
Old Feb 29, 2008
andyman97's Avatar
Turbo Guru
Yeah, I'm kinda between the false floor setup and wall. I'm leaning towards doing a wall because I actively use my spare tire well for various things. Anyone seen any nice looking wall setups with a clean, custom touch?
Old Feb 29, 2008
how about under the car spare tire relocation?
Old Feb 29, 2008
andyman97's Avatar
Turbo Guru
I may do that eventually but I still need the space, if nothing else, to store all of my tools. And there's a great idea, too. I may integrate my battery box into the floor....
Old Feb 29, 2008
heres mine, its as simple as you can get (single amp, no sub). cut hole for amp, and a lil window with plexi and binder plastic for the alpine sticker which looks neat at night with the red led dome light shining down. and a plastic flower pot to hold up the amp.
Old Feb 29, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
i'm thinking a wall... thats what i'm gonna go for when i eventually get there.
Old Feb 29, 2008
Rufus's Avatar
Mine
Old Feb 29, 2008
how much more raised is you trunk floor?? it looks pretty high...but it also does look good?
Old Feb 29, 2008
Rufus's Avatar
Ummm no clue. Look for posts started by me in the audio thread. You'll find build pics.
Old Feb 29, 2008
DsevenEm2's Avatar
This is Myspace
varner88 had a pretty huge wall built for his type-R. it was ok..
I need to build some kind floor for my amp/sub in a box combo. I have my amp bolted to the back of my seat because i stuffed a slice of MDF behind the seat under the carpet. so that looks nice.. but the sub is just rolling around back, disconnecting every few days..
in the floor sounds nice.. gearboxs was very clean
Old Feb 29, 2008
04[ivi['s Avatar
New Member
Heres a wall in a wall setup, shows how you still have trunk room.
Old Mar 1, 2008
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
but do you want sq, spl or just want to look pretty?i have a l7 in a custom built box for my car and i do 149 db on the windshield but my trunk looks like sh*t.if you want looks then do a false floor or fiberglass a enclosure. if you want a little more output then do a wall sealed.if you really want more boom then do a wall and have it ported with aeros facing the cabin so the back is just plain and you can still access the spare location by putting a trap door there.
Jeffdp
Aug 5, 2015 11:38 AM
cperez53
Apr 16, 2015 09:31 PM
GH04si
Apr 15, 2015 08:13 PM
djdefcon
17
Apr 6, 2005 11:52 PM
