OEM Black Gauges Installed
Old Mar 9, 2008
  #31
pheaton's Avatar
A descendant of 2k1civic.com
Re: OEM Black Gauges Installed
I have an '01 LX Coupe. How come I don't have the black gauges?
Old Mar 9, 2008
  #32
01 sedan only. coupes have the fugly greyish variation gauges lol. 02 sedan came with bright silver faces.
Old Mar 9, 2008
  #33
pheaton's Avatar
So if I want these I'm looking for the 01' Sedan gauges. The MT ones are black too I assume?
Yeah, as the time has worn on I'm getting damn sick of mine. They are fugly.
Where can I get these?
Old Mar 10, 2008
  #34
yeah, junkyard or ebay but the manual ones are super hard to find. i got the one for the op at a junkyard in reno, the only one they had sitting around. auto is easy to find. but fyi, sedans have greenish backlight not amber. so you would have to open it up and strip off the paint in the back, and put some red film or something.
Old Mar 10, 2008
  #35
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
I didn't touch the "green" backing, really. It looks white. At least that one you sent me did. No one can tell it's kind of green unless I tell them. It's not enough of an issue for me to warrant stripping it off and putting something back on there.
Old Mar 10, 2008
  #36
pheaton's Avatar
If I can find one, I was planning on doing the LED thing, so it'll be good. Again, if I can find one.
Old Mar 10, 2008
  #37
Unevolved's Avatar
Good luck with the LED thing, it's not as easy as it sounds. As long as you don't mind uneven light, it won't be an issue. Just don't expect it to be as even as OEM.
Old Mar 10, 2008
  #38
pheaton's Avatar
Yeah, I'm ready to cuss and be pissed and unhappy. I plan to sit in a dark room with the gauges plugged into a battery and keep on adding LEDs until it looks like I want it. Then either tape, or glue the hell out of it.
Old Mar 10, 2008
  #39
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
i have on 01 coupe MT. one light went out at the top of my odometer and the lights on my mileage went out. can i fix it or is it surface LED?
Old Mar 10, 2008
  #40
it is just a bulb you can get from dealer, and the socket twists off from the rear.
Old Mar 10, 2008
  #41
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
isnt there an online honda junkyard? in case a few of us would like some...
Old Mar 10, 2008
  #42
WEAPONX's Avatar
WEAPONX is an unknown quantity at this point
Yeaa I want one. This gray one is starting to **** me off.
Old Mar 11, 2008
  #43
Unevolved's Avatar
Honestly, I was looking for the cluster for the better part of a year, and Steve happened to stumble across one.
But in regards to stuffing it full of LEDs, best of luck to you. Not saying it can't be done, but I'm an engineering student that spent God knows how many hours trying to get a solution that worked, and I ended up having to buy replacement parts to go back to stock. But then again, I'm a perfectionist. Be sure to post up your attempts/results.
stryder12
Jun 30, 2015 08:33 PM
KronikScott
Jun 9, 2015 08:00 PM
AlphaInfinity
Nov 21, 2001 03:15 PM
meels808
Nov 9, 2001 03:08 PM
