Flasher Control???
Old Mar 9, 2008
breault5's Avatar
breault5 is an unknown quantity at this point
Question Flasher Control???
i have an 02 civic and i got a free..run-about flasher control.. which i guess can change the speed of your blinkers...i know it sounds ricy but im just curious how it it looks and how it works...so i looked up how to install it..
Locate the light wiring harness and stock relay
Remove the stock. (It should be a three plug relay)
Use an electricians test light to find the positive (+) power source plug
Connect the red wire from the Run-About control unit to the positive (+) ppwer source wire (It should be either gray or white)
Connect the blue wire from the Run-About control unit to the plug on the llight source wire.
Properly ground the black wire from the kit to the vehicle.
Test for proper connection
....sounds pretty easy to me but a couple questions??where is the light wiring harness and stock relay??? on my car???
i know there is a relay under the dash by the steering wheel and i also have one under my hood for my fogs...which one do i use or do i use any of them???
Old Mar 12, 2008
Rinasdaddy's Avatar
Rinasdaddy is an unknown quantity at this point
Re: Flasher Control???
*cough* rice *cough*
Old Mar 12, 2008
breault5's Avatar
haha yeah i know!!!! but im just curious!!!
Old Mar 12, 2008
TRIZ's Avatar
gearbox just had a post on the blinker speed relay. look for it and paste link in here.
robjcivic
Mar 12, 2017 12:10 PM
Klame9420
Sep 7, 2015 10:03 PM
99BoostedSi
Sep 7, 2015 04:49 PM
