remote start help please!
Looking for the imaginary red with black parking light wire on back of the fuse box, dont know bout you but there arent any wires on back of my fuse box. The car is 03 LX. Also is the factory alarm plug way up the drivers kick panel? I dont have a factory alarm and all the schematics say its the green plug up there.
Re: remote start help please!
Im using direct tech wiring diagram and all these others are talking about wires in the back of the fuse box. Im not real smart but i do know front to back, and it says the other parking light wire is in the green factory alarm connector in kick panel. BTW its a code a larm remote start with keyless.
The alarm connector is listed as "left side of dash" 16 Pin Connector. To me it looks higher and more to the right than kick panel.
The RED/BLK is at the same potential as the RED/YEL (switched lead of taillight relay) either should work.
The negative parklight wire (blue) originates at the light switch, runs down the column, and to the underdash fusebox (as well as the fact alarm plug). In my car I grabbed blue in the steering column.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
loquito
Nov 12, 2001 07:24 PM
