Should I Change My Head Unit?
Old Jan 11, 2008
J Casanova's Avatar
J Casanova will become famous soon enoughJ Casanova will become famous soon enough
Well the previous owner installed a jvc head unit in the car, probably because it is a dx and didnt come with a cd player. I dont really like the way it looks but i can live with it if it is too hard to swap em out. I have an older sony xplode head unit from like 2004 (not sure how old the jvc is), but im not sure how easy it would be to swap em out, or if its even worth it... Are there any problems with wiring or anything i would have to replace to swap the xplode into the car? Or is it as simple as pull one out stick one in? Heres the best pic i have of the mentioned jvc
Old Jan 12, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
Re: Should I Change My Head Unit?
It's definitely worth replacing. Thats the same head unit that I had in my car when I bought it. It's pretty simple, all you do it take it out and rewire the new one in. If your not handy with this kind of thing just take it to BestBuy or somewhere where they put in stereos and they can do it for you for around $50.
Hope that this helps!
Wagner
Old Jan 12, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
but its reallly easssyyyy to do. I had never even touched a car and it was my first mod. Just match the colors and solder, then plug and screw.
Old Jan 12, 2008
J Casanova's Avatar
thanks for the info guys. so your saying i would have to cut some wires and solder in order to swap this aftermarket unit with another aftermarket unit? i was thinking that since this one is aftermarket, all the wiring and whatnot would already be done, and all i would have to do is unplug it and plug a new one in lol
Old Jan 12, 2008
WgnrNick's Avatar
Basically, yes. Cut, match, and solder. I would buy a new wiring harness though that fits your car though. They are like $8 if that. Also, best of luck getting that headunit out. You have to rip apart just about half the car it seems like to get to it. I don't even remember where I found the directions and schematic to do it, but if I do I'll send it to you.
Wagner
Old Jan 13, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
half the car?! you just pull the HVAC part out as one peice. It is insanely easy to do.
Old Jan 13, 2008
J Casanova's Avatar
i might try to do this. Im good with mechanical stuff but electrical is my weak spot lol, but i gotta start somewhere! How much does a soldering tool cost though? And also anybody else have any specific directions or diagrams of what to expect lol?
Old Jan 13, 2008
Envy's Avatar
Diamond Member
a soldering iron cost like $7 at your local radio shack. for a cheapy. You could spend more if you plan to solder later.
Old Jan 13, 2008
WgnrNick's Avatar
You really don't even need to solder them if you want/ if you don't know how to. Also you could just use butt connectors. To be honest I think that they work better with less of a possibility of the connection coming apart.
Wagner
Old Jan 13, 2008
white04alero's Avatar
white04alero is an unknown quantity at this point
yeah.. if you arent sure about how handy you are just twist and tape..
butt connectors suck.. they have a tendency to fall out.. use them in your house not your car bc your car vibrates goin down the road.. you hit bumps and dips and what not.. just not a good idea in a car. they just arent secure enough
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
ACEM2
Dec 22, 2001 09:14 PM
