Attn Gearbox
Attn Gearbox
yes, its that time again, for you to bail me out! can you (or anyone else) give me the bulb sizes for the 01 civic lx 4dr mt guage cluser? one of the bulbs went out an i figure while i have the cluster apart, ill go ahead and replace them all. honda wants $8 a pop for these, so if i can get them elsewhere, that would be awesome. I asked about this before and someone gave me a link, but i have no idea what size these are. thanks
Re: Attn Gearbox
http://www.hondaautomotiveparts.com/
Look under Meter Components.
I think they are 12V 1.4W bulbs
Here is a direct link, Dont count on this correctly linking:
http://www.hondaautomotiveparts.com/...NENTS+%28NS%29
Diagram:
Diagram:
Re: Attn Gearbox
unfortunately, they are not standard size. you can take the socket to a store and try to compare what bulbs might fit, but they did not look standard. and 01 and 02 clusters use different sizes so make sure if you order from dealer, you give the exact info for your car. ive seen an older 01 cluster that takes #74 size bulbs, so you can try those but if they are too small, you gotta goto honda.
