Install a new head unit into a 2003 civic
Old Jan 4, 2008
316's Avatar
316
316 is an unknown quantity at this point
Hello!
I want to remove my old head unit and install a new DVD player. Does anyone know how to remove the old head unit?
Could someone point me to the right link, I tried searching but all I get is removing the head unit from other type of civic but not my model.
https://www.civicforums.com/forums/a...6&d=1198147586
for the link of the inside of my car
Thanks
Old Jan 5, 2008
electric130's Avatar
Re: Install a new head unit into a 2003 civic
search for how to do it on an Si. that's the way the Si interior looks here in the states.
Old Jan 5, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Pull shift ****. Pop off shifter trim bezel. Remove two 8mm bolts mounted thru bottom of radio. Entire radio/AC control bezel will remove as one.
Old Jan 8, 2008
316's Avatar
316
I managed to take the shift **** off ... but i am really struggling to get the shifter trim bezel off.
does anyone know how to remove that part?? i tried pulling it but didnt come off, i was scared to break anything.
i attached a pic of the progress i done so far.
Old Jan 9, 2008
316's Avatar
316
any idea how to remove shifter trim bezel??
The panel surrounding the gear stick, as shown in the picture above.
Old Jan 9, 2008
Well everything I can find shows it just pops off, but that it is very tight. Either way, you have to use an offset tool to get the bolts off so it might not be your best bet.
Try this instead:
Remove the driver side underdash. The tabs should just turn 90 degrees and the panel should come out.
Open the glovebox, and remove the glovebox stops. Let the glovebox hang down.
This should give you enough access to remove the two bolts that hold the entire center dash bezel in. After removing the bolts, the radio/AC controls bezel will all come out as one piece.
Old Jan 14, 2008
316's Avatar
316
thanks
i got it done, it worked, just like you explained.
Old Jan 14, 2008
Originally Posted by 316
thanks
Glad to hear it. That's what a forum is supposed to be for.
Old Apr 6, 2008
willb123's Avatar
willb123 is an unknown quantity at this point
Remove gear ****, squeeze boot and lift the lower panel along with it and it should free up a 6 o'clock. Coax the lower half of the panel off the shifter, the top panel including the radio follows pretty easily. Didn't have to use pry tools. Surprised me it was that easy.
Old Apr 7, 2008
yingjai's Avatar
yingjai is an unknown quantity at this point
from the pix of the bezel, it looks like it's just a snap on.. does this mean i can install my headunit b4 i get my bezel? i got my d3 before the weekend and i've been itching to put it in, but i've been having trouble getting a hold of the dash kit. (finally went to a more reliable retailer and it's coming in on wed)
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
mugenca
Apr 16, 2015 12:15 AM
deus-ex
Apr 13, 2015 12:29 PM
