first time head unit installation 2003 civic SI sedan
Old Oct 14, 2007
lanebmx's Avatar
lanebmx is an unknown quantity at this point
So I just purchased a new head unit for my car (JVC kd-bt1) and Ive figured out how to take the old deck out thanks to a great DIY on this site, but Im still not really sure on how to put the new one in. Ive read that I need a wiring harness but the head unit did come with something that I think might be one but I'm not totally sure. it also came with some screws and brackets, how will I know if I need these? Some tips on how to do the wiring connections and just general guidelines to installing this would be greatly appreciated.
Old Oct 14, 2007
85gp4's Avatar
85gp4 is an unknown quantity at this point
Re: first time head unit installation 2003 civic SI sedan
You need to purchase a stereo wire harness. It plugs directly into the factory wire harness and then allows you to wire the other end into your new head unit. Here's an example of a wire harness
Old Oct 17, 2007
desiinblack's Avatar
desiinblack is an unknown quantity at this point
hi there,
wel first of all u hav to strip de dashboard a bit..like de bottom part of the dashboard..nd der's a special lume for all de honda's u can get it from anywhere..i mean from a ICE shop...now de things which u hav to strip is de glove box side de centre panel n de drivers side bottom panel of de dashboard...den only u can see the bolts to screw off de head unit fittin..once u hav opened it screw on de brackets on de sides where ur headunit is suppose to go so it can hold de headunit..once its screwed den jus fit everythin back!!its a hard job but its easy...haha..i mean u rly need patience for tht..it took me 1nd a half day to put in de amp n bass system!but dun wry dis is only a headunit it will be easy.if u hav any further questions in which i can help..den jus dun hesitate to ask me!
thanks.
D.I.B
Old Oct 17, 2007
well 85gp4 is exactly right...as i told u dat u need a special lume for honda's may be u do have it but still its better off to check!coz i had to wait for 2 days for my lume!lollz.o yea nd a=does anybody knw here dat how to n where to find de 16pin scan socket on de honda civic vi-rs...its jus bein pain in ***...my srs light shows up in de dash!please reply if anybody knows in here!thankin uzzz!
usajags84
May 10, 2015 08:11 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Fastfebur
Apr 22, 2015 01:37 PM
mugenca
Apr 16, 2015 12:15 AM
deus-ex
Apr 13, 2015 12:29 PM
