Solution to Trunk Spring Rattle
Old Sep 26, 2007
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
For the longest time, my trunk springs would resonate violently when my sub hit certain low frequencies. It sounded like two pieces of metal clanging against each other. Originally I thought it was the rear shelf causing the ruckus because that's what a lot of people have trouble with. In the end, I narrowed it down to the springs and applied sound deadening to them. It worked like a charm. The only trunk rattles I have left are the ones caused by the trunk vent and the trunk latch but those are barely noticeable compared to the rattling caused by the trunk springs.
Anyways, I hope this post will be of help to other people that may have the same problem.
Old Sep 26, 2007
greeen01civic4d's Avatar
Re: Solution to Trunk Spring Rattle
man, that had to be loud, take some pics to share with us, id like to see what u did
Old Sep 26, 2007
mike21190's Avatar
mike21190 is an unknown quantity at this point
thanks for that. im edeading my whole trunk now and thats really helpful
Old Sep 27, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
or you can remove the springs altogether and do the trunk shock diy
Old Sep 27, 2007
turboslug's Avatar
Super Hoser
yups, but i didn't bother because it's more work than i feel like doing...
Old Sep 27, 2007
turboslug's Avatar
Super Hoser
all i did was wrap sound deadening material around the springs that hold up the trunk lid. it was a simple, cheap, and very effective solution to the problem i had.
note that not everyone will have trunk spring rattle though. if you're not experiencing rattling from the trunk springs, you probably don't need to sound deaden it.
lots of people seem to complain about the rear shelf rubbing against the rear window. my car doesn't have the annoying rattle from there so i didn't bother trying to fix a nonexistent problem
Old Sep 27, 2007
turboslug's Avatar
Super Hoser
btw, to tell whether if your rattle is caused by the trunk springs, sit in the back of the car w/ the seatback folded down. turn up the subwoofers, and when you hear the rattling, grab the springs w/ your hands to stop the rattling. if the rattling doesn't stop, the trunk springs aren't the problem.
note that the trunk spring rattle doesn't happen with the trunk lip flip open.
Old Sep 27, 2007
you can also pound on the deck lid from inside and see if you hear a springy type sound lol.
Old Sep 27, 2007
turboslug's Avatar
Super Hoser
i've tried it but it didn't work very well because the trunk spring rattle happened only at certain resonant frequencies...
Old Sep 27, 2007
turboslug's Avatar
Super Hoser
i guess i should throw in an extra hint. it you want the sound deadening install to look good, it may be easier to wrap the springs if you remove the springs first. that's what i did because i had the honda trunk spring removal tool.
note i also used a super thin deadening material because for wrapping a small diameter rod, it was easier to wrap a few layers around the rod rather than one thick layer. don't ask where i got the thin stuff. i got it for free and don't know where to get more.
Old Sep 27, 2007
PopcornPlaya's Avatar
Electric Boogaloo...
Slug, why didn't you throw them in the garbage while you had them out and replace them with struts? Opening the trunk is easier and rattle isn't a problem either.
Old Sep 28, 2007
turboslug's Avatar
Super Hoser
haha, i would but there are so many other things i want to get done on my car before trunk springs becomes a priority...i actually had the shock kit but sold it after letting it sit around for more than a year.
my fix was cheap because i got the sound deadening for free...it was also easy because i had the honda trunk spring removal tool lying around
skeener51
Oct 1, 2015 05:56 PM
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
260000milesgoal
Sep 25, 2015 07:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
