neep help!!!!! amp bazooka ahhhhhhhhhhhhhhhhhhhhh
Old Sep 14, 2007
hotdealz25's Avatar
Member
hotdealz25 will become famous soon enough
hello im currently trying to set up my bazooka sub into my car its that it seems like theres a shortage of wires or maybe im looking at this wrong has anyone done a bazooka set up before? please reply i have a bazooka EL 10 inch with a powered amp built in please reply back or email at saurael@tmail.com
Old Sep 26, 2007
hessdawg's Avatar
hessdawg is an unknown quantity at this point
Re: neep help!!!!! amp bazooka ahhhhhhhhhhhhhhhhhhhhh
factory deck or aftermarket deck???
you will probably need a 10 ga amp kit
Old Sep 26, 2007
sl33pyriceboi's Avatar
^id get ATLEAST a 8awg amp kit/wires....
Old Sep 29, 2007
hotdealz25's Avatar
Member
yea i bought a 8 g wire set up and i have a after market set up guyz
Old Sep 29, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
So what are you missing then?
You have 8AWG power and ground.
How about RCAs?
Amp turn on wire?
Speaker wire?
I can't think of anything else you'd need.
Old Sep 29, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
since you have a built in amp to your sub (i'm thinking tube enclosure), you should only be looking for a power and ground to the sub, a remote turn-on and signal (line or RCAs) from your HU. unless you have one with the remote gain control...
let us know if you figure it out
Old Sep 30, 2007
hessdawg's Avatar
i do agree that bigger ga wire is better but the bazoka requires like 15 to 20 amp max. you don't need 8 ga.
Old Sep 30, 2007
DsevenEm2's Avatar
This is Myspace
crutchfield master install sheet. search for it.
Old Oct 1, 2007
85gp4's Avatar
85gp4 is an unknown quantity at this point
I have a Bazooka EL 8" tube in my S-10 and the hook up is simple.
Battery, Ground, Remote Power, and RCA. All those other wires are only used if you don't have RCA cables and need to use high level input (speaker wires).
Old Oct 1, 2007
hotdealz25's Avatar
Member
cool ill let kno since ive been supa busy
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
