Sub keeps shutting off
7thgen Terminator Ninja
For some reason my sub keeps shutting off, and i think it's due to lack of voltage. when i have the a\c on full blast, and the headlights on, and the stereo off, it's at 12.6-.9 at the battery...so it's low. When everything is off and the car is idling, it's at 13.8..reved goes upto 14.17 and about the same at my 1.7 farad cap. I've ran all new power wires from the battery, 4 awg...from the starter, relay box, altenator, grounds, everything. grounds on the amps are less than six inches long, with self tapped, sanded connections. tried disconnecting the cap and it made it worse. Every now and then i think i hear the alt. belt squeakin so i'm thinkin it might be slipping and causing the alt not to work as good as it should...any ideas?
Re: Sub keeps shutting off
upgrade your battery to a konetic one. it matters how big your amp is pushing for your sub. my sub use to drain my battery.had to upgrade battery bat cap and that helped alot
already have a good battery, not a optima, but the best i could get at autozone lol, i know it's nothing that special, but should at least do this, not like i have 15 subs or anything, it's one kappa perfect on a pioneer 800w amp
I have a kappa perfect also awesome sub btw. Might want to make sure its the sub thats causing you problems. Im having similiar problems but for me the amp is shuttting off and on.
So is the amp turning off then? Is it temporary? Comes back quickly?
Do you only lose sound during the voltage drops you mentioned?
What kind of amp? Mono or 2ch? Is that kappa perfect dual 2 ohm or dual 4?
the amp is a mono D block, it doesn't shut off, (or at least the blue light on it stays on, there's no other lights or anything) and the Kappa perfect is dual 4 ohm coils...it used to work great but just started doing this...i have another identical amp and i'm thinkin of tryin that tonight...
edit: it shuts off for just a short amount of time depending on how loud it is, and if i turn something off that uses a descent amount of power (headlights, a\c, power windows, etc.) it'll stay on longer
That's what i'm thinkin too, i guess i do have a lot of electric stuff and all, (remember it's a dx) i put in power windows, locks, and my m-audio for the sub, then for audio i've got a blaupunkt 500w, a bolt 400w on it's our 4awg power wire then the cap and sub on another 4 awg...I'm wondering if i need a bigger altenator or if mine is just bad...
well, i have that same problem too kinda...but mine is simply that i replaced my blown fuse with one thats too high, and when the bass was really loud, the subs would cut out, i replaced the fuse to something smaller, and it fixed the problem
my sub ended up blowing last week for no reason lol, wasnt loud or anything, so i put a kicker cvr12 in it's place and it actually sound better...i used to love infinity, but now i'm iffy on their subs, everyone i have ever had has blown...
Yea i had a cvr 12 before that looked like a VOIT ball, then i got this one, i just wish i could run it at 1 ohm, but my pioneer likes to blow fuses when i try to lol so 4 ohms it is
solarpunk70
Apr 12, 2016 11:43 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
