amp problems
Old Jun 5, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
amp problems
Just made a jump up from an alpine mrp350(350 watts rms) which i had powering my sub to a kicker 550.3(~550 watts rms) which powers my components and a sub. The problems is the amp cuts out whenever the voltage changes like when I open my windows or step on the gas/brake, I have a radar detector and it shows my cars voltage. Its fine though when I'm cruising at a steady speed. Im pretty sure its not the ground/power wires. Any ideas how to fix this or what the problem is?
Old Jun 5, 2007
2k1_Toaster's Avatar
2k1_Toaster will become famous soon enough
Re: amp problems
You are trying to pull too many amps through too small a guage of wire.
The wire you used to hook up your amp is insufficient.
What did you use, and how is it wired? Where is it grounded?
Old Jun 5, 2007
Re: amp problems
Its hooked up with 4 gauge wire and I drilled a hole and sanded the paint where its grounded. Its grounded to a part of the frame behind the rear seats
Old Jun 5, 2007
Re: amp problems
4 guage to where? Direct to the battery, or to some other point?
Old Jun 5, 2007
DsevenEm2's Avatar
This is Myspace
Re: amp problems
geez 4 gauge should be cutting it. but like toaster said where is it going. do u have 4 gauge wires all the way from ur amp to the battery or does it cut off and turn into a smaller gauge.
Old Jun 5, 2007
Re: amp problems
its 4 gauge from the battery to fuse to amp and 4 gauge from amp to ground
Old Jun 5, 2007
sl33pyriceboi's Avatar
Re: amp problems
make sure ur grounding it well... not just some small contact point...
Old Jun 5, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
Re: amp problems
it may be your alternator going out. either that or check your battery. if they check out fine let me know and ill tell you what else to check and diagnose.
Old Jun 13, 2007
electric130's Avatar
Re: amp problems
put a voltmeter on your car and take readings with the system on and see what it drops to when you do what normally makes the amp cut out. if the voltage drops a ton, you may need a bigger alternator.
this is proabably a stupid question, but i hope you did upgrade the ground wire from the battery to the chassis....didn't you? the stock cable is not 4ga. if you're running 4ga for the stereo system, you need at least 4ga if not 2ga for the battery to chassis ground. the battery to chassis ground could be your bottleneck if you didn't upgrade it.
Old Jun 13, 2007
civicfan1203's Avatar
Look at me im a supporting member
civicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nice
Re: amp problems
my power wire is 5 gauge with a dist block with a 8 gauge going to my amp
Old Jun 13, 2007
Re: amp problems
what does that have to do with this thread?
Old Jun 14, 2007
Re: amp problems
yea i did the big 3 upgrade with 4 gauge wire. amp cuts off when the voltage changes quickly like going from 14.1v <---> 12.1v or something close. Maybe something to do with the alternator coming on and off?
I suspect it may be the battery its oem and theres no "green eye" i dont know when the battery was last replaced, it might even be the original battery from 01 getting it checked out soon and probably replaced
Old Jun 14, 2007
Re: amp problems
yeah, your voltage shouldn't jump that much. get the battery checked out.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
