Remote control stops working
Old May 27, 2007
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i have an oem alarm...and suddenly 1 remote control stops working...even w/ a new battery.
help would be appriciated. thx
Old May 27, 2007
Re: Remote control stops working
does the other remote work?
Old May 27, 2007
G617's Avatar
G617 is an unknown quantity at this point
OEM Alarm brain might be dead or the antenna may not be communicating with the transmitter. I don't think the OEM alarm is like the 6th gen's alarms where it's tied into the radio. I'd go aftermarket like DEI (Viper, Clifford, Sidewinder, Python, Avital, etc.) or Autopage. They're better alarms. Just my 2 cents.
Old May 27, 2007
CraigW's Avatar
LED on the remote lighting when buttons pushed ??
Old May 28, 2007
yes the other remote works
no the LED light does not go on when press buttons
man its so annoying...lol
Old May 28, 2007
Civicman1988's Avatar
sounds like the brain is dead in the remote
Old May 29, 2007
eff!!
Old May 29, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
take it apart and give it the thorough look over if the led isnt lighting up
Old May 29, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Look for broken solder connections between the circuit board and the part that holds the battery in.
Old May 29, 2007
TRIZ's Avatar
use the other remote.
Old May 29, 2007
sl33pyriceboi's Avatar
get a new alarm. they are cheap. any way better than oem
Old May 30, 2007
thx guys, ill proply get a new remote and have it programmed to the car
Old May 30, 2007
why do you need two? just use the other one. and open up the broken one. alot of times you just need to clean the metal contacts with alcohol (remove battery first obviously)
Old May 30, 2007
BigD001's Avatar
BigD001 can only hope to improve
Im have a problem with mine too and my radio, the led light works and there no power to the radio, I just swaped my gauges to the type-s. No blown fuses, can anyone help?
MamaBear2015
May 3, 2015 02:17 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
klam
Nov 16, 2001 03:36 PM
