Rear deck bottom mounting speakers
Old May 15, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
2002 Civic LX sedan. Was wondering if anyone has ever mounted speakers in the back from the bottom to deal with top height issues. I have a pair of polk db650s that I want to put back there. Was there any cutting needed to open the hole up more? I know one of you mentioned doing this but never mentioned if there was anything speacial that had to be done.
Old May 15, 2007
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
Re: Rear deck bottom mounting speakers
you'll have to remove the trunk springs that keep the trunk open and then when you go to put your head in the trunk it'll shut on you lol i just put mine through the top..
Old May 15, 2007
Alpha 5's Avatar
Mine are mounted from the bottom and I did not remove anything. They fit fine.
Old May 15, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yeah I've done this in several cars without issue. As someone else here stated previously it makes for gravy warranty work.
Old May 15, 2007
does it still sound okay?
Old May 15, 2007
Not sure if this was directed at me but I've never been too concerned with the subjective sound quality of rear speakers. I've also never had a complaint from someone when I mounted their drivers this way. I could see the potential for some diffraction issues but in a car environment there's plenty of other things that degrade sound to worry about before diffraction.
Old May 15, 2007
well true but i depend on the rears for most of the bass. fronts give some but the rear is much better at that. fronts are good for everything else and makes it sound balanced. but yea as far as most ofthe sound i cant hear anything from the back except bass.
Old May 16, 2007
ryox82's Avatar
The whole reason I had posted this question is because the polk db650s have a top height issue...i am having trouble even getting them in the door....stayed home from work for a trip to home depot....lots of shaving and cutting :-) and I need my own drill.
Old May 16, 2007
ryox82's Avatar
Also, I would asume that if there is no interference with the cone and the surround from the metal, if mounted right....shouldn't cause too much of a problem....I have been talking to alpha about this over PM's and he hasnt mentioned any SQ Issues.
Old May 16, 2007
electric130's Avatar
what height of spacer are you using for the door speakers? if you're not using a spacer, then that's an issue too. those have a 2" top mount depth, so you'll need at least a 1/2" spacer to get them to clear the window in the door when it's down. if you use a 1/2" spacer, it should fit no problem. i got infinity reference 6.5's to fit with a 3/4" spacer which put the surface height of the speaker a little over an inch. the bottom mount depth of your polks is 2-5/16". so even with a 1/2" spacer, your height should be less than an inch and fit just fine. i don't know what the clearance is with the rears and the trunk springs.
Old May 16, 2007
ryox82's Avatar
All was finished with the rears and fronts. They looked like 1 inch spacers and thats all crutchfeild had. A tech there was sending me out some ABS plastic sheets to custom my own for free but I on Alphas advice I just took a razor to the door and cut down the circle on the door on the grill, basically down flat to the grill. Fit fine after that. I asked if they had 1/2 inch spacers first of course but they did not.
Besides swapping PM's with Alpha I read up on your DIY electric and it helped alot in the door removal and all so props for putting that up. I dont have a saw though and I JUSt picked up a drill of my own today with some good quality bits and now I am just waiting for m RAMMmat and Ensolite to come in so I can tear it all down again and REALLY have some fun.
I bought rotors too today and INTENDED on putting them on but I could not get those calipers off for the life of me
JohnnyBxo
Nov 12, 2015 03:04 PM
mistermenphis22
Jul 13, 2015 04:43 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
SpecialRequest
Jul 7, 2015 07:52 PM
Causemo
Jul 4, 2015 07:11 AM
