sub doesnt work when balance is set all the way to the right
Old May 7, 2007
vino's Avatar
vino is an unknown quantity at this point
i was playing around with my hu and noticed when i set my balance all the way to the right my subwoofer doesnt work. i did it to the left and it worked. i also tried it with the fader and it worked. what could the problem be?
Old May 7, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: sub doesnt work when balance is set all the way to the right
Could be a bad channel on either the deck or the subs. It could be bad RCAs or that the RCAs are not plugged in on one end or the other. Depending on how things are wired up it might even be a bad voice coil on a DVC (seems unlikely though). What kind of equipment do you have? Can you check RCAs are plugged in solidly everywhere, maybe try swapping left & right RCAs at the amp and seeing if that makes it so it only works balanced to the right.
Old May 9, 2007
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i think it's just a cheap design on the deck where if you configure the sub outs to mono mode, the deck just sends the right channel to both sub-out RCA's
Old May 10, 2007
vino's Avatar
its an alpine hu. still havent gotten a chance to play around with the cables. doesnt really bother me much since the balance is always set at the center anyway
Old May 11, 2007
electric130's Avatar
1 sub or 2? 1 RCA cable or 2 (single or stereo cable)?
Old May 17, 2007
turboslug's Avatar
Super Hoser
i know the alpine cda 9835 does that ifyou set the sub to mono mode...i wouldnt be surprised if other models do the same thing...
jbradley4809
Apr 7, 2017 04:23 AM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
GH04si
Apr 15, 2015 08:13 PM
RickyRocket
Nov 30, 2001 10:14 AM
