OEM style 2005 civic fog lights (wont work)
Old Apr 8, 2007
Corvetteo2001's Avatar
Corvetteo2001 is an unknown quantity at this point
Hooked up lights to stock fuse box and honds switch. will not operate when I put power from battery to lights under hood at first plug in will not operate, have solid ground at that point. ckecked connections all ok. any suggestions? Thank You all...
Old Apr 8, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Re: OEM style 2005 civic fog lights (wont work)
Well its in the wrong section but its your first post, hehe. How much do ya know about electrical? Did ya make sure you have power going in and out of the switch and into the lights? If not grab a test light and double check. Try taking out the lights and test them with the battery and straight wiring to eliminate the possibility of them not working for some reason. I know these are generic tips but its kinda a generic question. Pics and lots of info help when you are asking questions on the net.
Old Apr 8, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
are your headlights on ? Foglights will only work when your low beams are on if your using the Honda switch
Old Apr 11, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
check the fuse for the fogs again ... if there from EBAY theri shyt ... u might have to change em ... if there OEM listen to the guys above me
Old Apr 12, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
might be relay or inline fuse
Old Apr 12, 2007
kasimmmmm's Avatar
any fogs are pain in the *** because of wiring... if you're 100 percent about the wiring, then it has to be the fuse. sometimes its the switch itself. Do you have the tool that reads if there is power in the wiring? those will help a lot. that will tell you if its the fuse or something...
Old Apr 12, 2007
TRIZ's Avatar
"OEM Style" = ebay... I picked up a switch from autozone and fit it in one of the switch spacers. power from the battery, ground, wire to the fog lights... works without the lowbeams on, or the parking lights, or with the highbeams... too complicated. what if u just want to drive around with the foglights on in really bad weather? Forget thoes switches and hit autozone
Old Apr 12, 2007
Mr. Beefy's Avatar
Mr. Beefy is an unknown quantity at this point
check the inline fuse and the relay....i had the same problem with my piaa harness and after about half an hour of checking wires,fuses and cussing at it. i found out it was my relay
Old Apr 12, 2007
lownloudnyc's Avatar
lownloudnyc is an unknown quantity at this point
I bought thoes ebay ones, they worked for a while but then they were flickering, and then eventually went out compleatly. all i did was rewire the the whole thing with a larger gage then they originally came with. not its been over one year and no problem.
Old Apr 12, 2007
Rufus's Avatar
I got an Autozone switch as well. Solved it all.
CarStuff
Dec 6, 2020 12:52 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
dano2005
Apr 14, 2015 01:58 AM
AlpineCivic
111
Oct 20, 2003 07:31 PM
