Power Outlet too tight
I have read previous posts (none of which I can find now) about people getting plugs stuck in the power outlet (one was an iPod). I never thought anything of it since I rarely use the outlet. Well, my wife has a slow leak in her driver's rear tire so I purchased one of those cheap air pumps. Don't you know that the plug got stuck in her outlet and the crappy plastic plug ended up breaking to get it out. Her car is an 04 Accord but my 01 Civic was pretty tight too. Is there anything that can be done to make the outlet more useable?
The only thing I can think of is maybe some grease in the outlet. I guess some dielectric (?) grease would be the better option if this is even an option. Any advice?
Oh, and if you're worried, the slow leak is from a nail in her tread that she will hopefully be having plugged soon.
Re: Power Outlet too tight
I would try another plug (sounds like yours is broken at his point anyhow)
Maybe the size specs on the new plug will be better than the one on the compressor.
You could try to push in on the 2 metal tabs to try to make better fit (less outward tension)
A lot of the items I plug in fit tight as well.
A far as the tire goes I would get it patched instead of plugged IMO.
I was able to return the cheap pump and get a similar replacement pump (same cheap plastic plug). I'll try pushing in the prongs and hope for the best.
And I thought a tear was patched and a hole was plugged.
its more the accessory than the car. ive had plugs that were loose and would almost not work til i rotated it, and ive had some i really had to pull to get out. just depends, most individual companies dont make them to the same spec as oem.
of the car he was driving. Plugs have become popular. Thread
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Dave1984
Jul 22, 2015 06:10 PM
CivicsClass101
Jul 9, 2015 11:14 AM
