Amp install help
Old Mar 16, 2007
speedracer2411's Avatar
speedracer2411 is an unknown quantity at this point
Amp install help
I just recently got this 05 civic so i dont know my way around it to great. Anyway below is a picture of the deck i have in it im not sure what it is but im pretty sure its a honda option deck. So my question is will this deck have an output for a amp/sub, also will is have a amp remote wire. If not is there somthing I can buy to get those two things on the deck, because i dont really wanna remove it because its half decent and matchs the interior lights. Also could someone point me in the directon of a DIY deck removal.
Thanks all its really appreciated
Old Mar 16, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
heres a link to the crutchfield master sheet that was just posted
Old Mar 16, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
There is a DIY head unit removal on this site that is pretty good. As for having pre-outs for a amp on that head unit, I cannot say, but there are ways of connecting an amp without preouts. The remote lead simply connects to the 12volt accesory power wire that leads to the head unit. If you have a digital multimeter, it will be the wire that reads 12+volts when the key is turned to the accesory on postion, or when the car is turned all the way on. Then, if your amp has high level inputs, you can connect them to your speakers to recieve and audio signal. If you dont want to do it that way, and you feel like spending a nice chunk of change, JL Audio makes a magic little box called "cleansweep" that is made for connecting factory stereos to after market amps.
Old Mar 16, 2007
JMUCivic03's Avatar
https://www.civicforums.com/forums/1...rsion-2-a.html
Thats the link to the head unit removal DIY that I forgot to include
Old Mar 16, 2007
TRIZ's Avatar
http://www.caraudiobook.com/car_audi...stallation.htm
Old Mar 16, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
The deck does not have RCA pre-outs for an amp. However, JL audio is not the only solution. There are high level converters. Take a look at the link.
http://www99.shopping.com/xPC-Scosch...www.google.com
This is not the only brand, but it was the first brand I found on google. I'm not sure what the cleansweep from JL is, but I'm pretty sure it does the same thing.
Old Mar 17, 2007
HotShotMedic's Avatar
HotShotMedic is an unknown quantity at this point
go speaker level inputs on the amp and tap into the speaker wire with self tapping clips. thats how i used to do it before getting a decent hu.
Old Mar 20, 2007
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Re: Amp install help
better recommendation - get a higher quality aftermarket HU - Alpine will work very well.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
