Problems with alarm
Old Mar 11, 2007
DTTheEmperor's Avatar
DTTheEmperor is an unknown quantity at this point
Problems with alarm
I been having some problems with my car's alarm. Well it does lock and unlock, but the horn doesn't make any noise. I check all the wiring, and everything is in working order. So do I need a new horn for my alarm??? Any suggestions??
Old Mar 11, 2007
CraigW's Avatar
Does the horn work when using the horn button ??
Old Mar 12, 2007
I forgot to mention that it is an after market alarm and no the horn doesn't work when I press the horn button.
Old Mar 12, 2007
CraigW's Avatar
7th Generation ??
The horn relay and one of the other relays can be swapped as a simple test to rule out the horn relay. (the horn relay is the middle relay in the group of three relays on the far left of under-hood fuse box)
Not likely the relay more likely the horn itself, Do you have a test light or volt meter available ??
Old Mar 12, 2007
yes i have a test light and i think it is the horn relay that is mess up. Do you know anyway it can be replaced and thanks for the info.
DT
Old Mar 12, 2007
CraigW's Avatar
So it does use the factory horn ??
I was thinking after posting it may use another (siren type) horn. (they are for the most part a speaker)
The relays just plug in and out, The horn relay is the center one in the group of three on the far left of the under-hood fuse box. You should be able to here the relay click and possibly feel the click if you touch it.
Check that the part #s printed on the relays match (the ones in my 05 do) and simply swap it with one of the matching relays above or below the horn relay. (use a Sharpie and put a small H on the relay so you can keep track of its origin)
If it is not the relay the horn itself would be next to test. Tough to get to on a 7th gen Civic.
civic1316
May 29, 2015 05:13 PM
Laurenhunter7
May 10, 2015 01:09 PM
pincookie1
May 4, 2015 12:22 PM
MamaBear2015
May 3, 2015 02:17 PM
Linda0818
Apr 23, 2015 11:30 AM
