Help....low beams not working, parking lights and high beams do.
Old Jan 27, 2007
wambo's Avatar
wambo is an unknown quantity at this point
I must admit that I'm not very mechanical.
I have a 03 Civic LX, 4 door. I noticed this evening that my low beams do not work, but my parking lights do, and my high beams do. When I turn on my lights, it acts the same as when I turn on my parking lights. No low beams on either. I've been told it sounds like a switch, which can only be purchased from a dealer. Is this true? If so how much should it run, and is it easy to replace?
I live in an area where most of the roads are lighted so I'm not sure when this happened.
Thank you.
Old Jan 27, 2007
CraigW's Avatar
There was a recall for 01s and some 02s for a defective headlight switch and/or connector pin.
Possibility of 2 blown bulbs.
Old Jan 29, 2007
wambo's Avatar
Thank you. Oddly enough, yesterday one low beam worked and the other didn't. I had a mechanic replace the one bulb and all is fine.
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
eXNBP
Dec 9, 2001 12:32 AM
GhettoCivic
Nov 12, 2001 03:15 PM
wawacito
Nov 5, 2001 03:32 PM
NukeSilo
Nov 4, 2001 09:37 PM
