headlights
Old Jan 9, 2007
2K5CIVICBOY20's Avatar
2K5CIVICBOY20 is an unknown quantity at this point
headlights
yes i have an 05 civic with Eagle eye projector headlights. im trying to adjuct the aiming on it, i can get to up and down...cant find where to adjust it side to side...does anyone know? ive tried searchiong. cant find anything on these headlights. thanks for your help.
**is that projector lense replaceable? ive heard u can take it out out and put in a fog light lense...or use the one fron the tsx?***
Old Jan 9, 2007
sl33pyriceboi's Avatar
no you CANNOT simply replace the projector with a fog lense or tsx projector....that requires alot of modifying....
there are two adjustment screws near the rear of the projector hosuing..
one for left n right, and one for up n down.... you might not be able to reach the left and right screw though
Old Jan 9, 2007
TRIZ's Avatar
Swaping the lenses requires a retrofit- meaning making something go in a place where it wasnt ment to be. I dont know why a foglight lense would end up in a headlight- that just seems crazy. If you cant access both screws, you may just need to take the headlights off or remove the fender- dont think the fender would work now that I think about it, depending on where your projector is placed on the headlights relative to.. ahh whatevers, you know what I mean.
Cleap projectors look dusty, or have ripples in them, or anything else becides a clear piece of glass. If you can get down and see your bulb and sheild, your halfway there to having a decent set of lenses. They just need to be aimed and have a good beam pattern.
hope you get em aimed, I been driving around blinding drivers for 2 months now- just havent had time.
Old Jan 10, 2007
thanks alot TRIZ. ill see if i can work on it this weekend. ill let you know. thanks alot
Old Jan 10, 2007
kornsined's Avatar
retrofit may or may not be hard. no one's taken apart these 04-05 projectors yet. With the current projectors in them the HID beam is decent.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
