dude messed up my clock
Old Jan 7, 2007
zonk's Avatar
zonk is an unknown quantity at this point
he was wiring my radio and touched metal witht he switch on and boom isntant problem, now my clock wont hold a steady time and resets everytime i start the car, now it is more of a minute counter onmy way to work. all i know is it was a yellow wire that touched and screwed everything up. what can be done to fix this?
oh yeah 92 dx hatch...forgot to add that
Old Jan 7, 2007
CraigW's Avatar
If lucky, only a constant power source fuse. Are other items like the dome or trunk light out as well ? Look in the fuse boxes for open (blown,defective) fuses, should also be some spare fuses located in the boxes as well.
Old Jan 7, 2007
zonk's Avatar
the car is like the lowest grade of lowest...minus the fact it has a factory tach and a/c.....
dome light works, has no trunk light....fuses are fine...
Old Jan 7, 2007
AmbulanceMonkee's Avatar
Sounds like it's wired wrong, and not getting any power when the car is off. Do you radio station presets stay, or do those get wiped out every time you turn the car off too??
Old Jan 7, 2007
zonk's Avatar
the stations stay preset, i have no problem with that, just the clock..
Old Jan 7, 2007
Something in the radio itself is fried then. Who is "the guy"??
Old Jan 7, 2007
zonk's Avatar
a staff sergeant i work with, he is a decent mechanic and good with his hands as far as working on stuff but i think he screwed up on this one
Old Jan 7, 2007
Yeah, sounds like you're gonna need a new HU. Before you do that, I guess you could try taking it apart and see if there is a blown fuse or loose connection on the inside. Maybe the jolt just popped a wire off somewhere.
Old Jan 7, 2007
zonk's Avatar
i just remembered the clock on the radio and the clock on the dash are seperate, my car is 92 not a 7th gen.....i would like a 7th gen but cash flow is low right now
Old Jan 8, 2007
Oh, i have no idea what it is, then. I just assumed it was in the radio.
Old Jan 8, 2007
zonk's Avatar
nah it is wired up seperatley, i purchased the clock off ebay because the dx had the wiring for the clock just not the clock.
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
tropicola
Sep 25, 2015 07:02 PM
speedlever
Sep 24, 2015 07:18 PM
