Hooked up some subs ... but they go in and out... help me out
Old Dec 13, 2006
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
Installed this in a friends truck. We installed 4 15s. But when I turn the volume up halfway the subs go in and out. I checked the clipping light on the amp and it doesnt turn on so I dont know what the problem could be. I have 2 15s MBQ hooked up to 1 1000w MBQ Amp (Rockford Power) same amp. I hooked up the other two and it was the same thing. Can anyone help me out? Hes also has a yellowtop and a 12 farad stinger cap.
Old Dec 13, 2006
LudlamTheory's Avatar
i boogie for the raindrops
my guess being the ohm load being too low
Old Dec 13, 2006
burke420's Avatar
The World Is Yours!
yah...the bass is drawingg too much current from the stock alternator i assume. my does this. get another, HO alternator... ie laterstart, Ohio Gen., irraggi, etc. that problem will stop. or loose wires, ground upgrded?
Old Dec 13, 2006
vietfob714's Avatar
Those amps are 1 ohm stable. put each sub @ 2 ohm and put it in parallel.
Old Dec 13, 2006
Pickles's Avatar
Pickles is an unknown quantity at this point
they the moving in and out slowly?? could be the ohms load is too low maybe or an amp problem, ive seen this happend to 5.25s in my buddys door it was bc of the amp. also check your rcas in the deck and amp could be something small!
Old Dec 13, 2006
vietfob714's Avatar
The sound goes in and out... not the actual sub
Old Dec 13, 2006
Black-EM2's Avatar
Black-EM2 is an unknown quantity at this point
sounds like a battery/alternator problem...upgrade it
Old Dec 13, 2006
Pattycakes's Avatar
Pattycakes is an unknown quantity at this point
12 farad capacitor, that's a huge biach !
Old Dec 13, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
check the gain, it sounds like its sending it into protect at high volumes, if the gains been messed with and you have a dmm, take it and measure how many volts its putting out, set it to this formula:
volts = square root of RMS times Ohm load
Old Dec 13, 2006
Srimmer2345's Avatar
New Member
Srimmer2345 is an unknown quantity at this point
sure its a stinger cap? stinger doesnt made a 12 farad cap.....not trying to start **** just an observation... im gonna guess ground issue, amp problem. ive got a 1200.1 planet audio and 300.4 planet audio amp, interior led's HID headlights, in dash dvd player, running off of stock alternator, stinger battery, and three farad stinger cap and my voltage doesnt ever drop below 12 volts even while pounding the system...... under normal listening levels stays at about 13.5 volts
Old Dec 13, 2006
ragingSPAM's Avatar
I just burnt my tongue
check ur grounds too
Old Dec 13, 2006
vietfob714's Avatar
My ground is kind of long... would that cause the problem?
Old Dec 13, 2006
vietfob714's Avatar
Heres a link to the 12 farad cap.
http://www.carsound.com/articles/pub...icle_714.shtml
Old Dec 14, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
The shorter the better, but length isn't nearly as important as quality of connection. Scrape away all paint and for best connection use a nut and bolt.
Old Dec 14, 2006
what amp is it?
Old Dec 14, 2006
New Member
i stand corrected been an avid stinger user for years and never seen that cap before.
like i said before if youve got the optima battery i gotta stick with a grounding problem. im running roughly 2400 watts rms, in dash dvd, interior leds, and HID headlights and i have no problems at all. stinger battery, 3 farad stinger cap.
Old Dec 15, 2006
i still think its an ohm load issue
i've run upwards of 2500 rms (am actually in the process of installing 3000 rms) on a stock civic electrical system...
amps never shut down on me
Old Dec 15, 2006
m3mo15's Avatar
m3mo15 is an unknown quantity at this point
4 subs 2ohms each on 1 amp i believe ur running a total of 0.5 ohms, and such a big cap i dont think u need, i think the rule of thumb is 1farad per 1000 watts but w/e floats ur boat. so u may wanna double check ur ohm load, to be sure. well good luck.
Old Dec 15, 2006
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
sounds like an alt/battery issue...check those out first
Old Jan 23, 2007
Pickles's Avatar
checl your ohm load it may be puting ur amp into protect mode
UltraHDGames
Jun 8, 2016 05:16 PM
Hutch1051
Sep 29, 2015 09:20 AM
pilebuck13
Sep 21, 2015 10:45 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
