Please help...need foglight wiring tips!
there is a hole in the pass footwell, but its hard to poke through. i used it and its possible, easier is under the driver footwell but you might need to drill a hole under the rubber part if you never got any alarm or system installed.
There is a large grommet on the passenger side. You can see it clearly from the engine bay if you have a CAI installed. If not, then remove the stock noise suppression air box. From inside, remove the passenger side panel from under the dash/glove box then pull back the carpet a bit in the foot well. You'll see the same grommet. In the engine bay the grommet has a large boot-like tail, under the dash its just round and fairly flush. You'll see the wires running through it.
Use a stiff piece of wire or a coat hanger to push through the middle of the grommet and get a lead. Make sure you tape the end of the coat hanger or something to ensure the end isn't sharp or you may end up piercing some wires (which you don't want to do).
Now you can simply tape the wire you are running to the end of the coat hanger and pull it back through....slowly.
^thats teh hard way....i looked and looked but my small asian eyes didnt find it....
ahaha i just installed mine yeterday...ill get some pixs up n show u my rout...its super easy...
it basically goes thought teh driver side door
fist things first, UNPLUG ur BATTER NEGITIVE TERMINALS to prevent all accidents. (important step that people neglect)
then take off ur bumper...
cut holes where ur gonna put ur fog
(im sure u did this already)
wiring:
ok so first take off the plastic shields... 1 below the steering wheel, and one below that.
below the previous shield
NOW IS THE IMPORTANT WIRING PATH...
if you look at ur driver side door, there is rubber grommet that runs from the door to the side panel of ur car (its for ur radio, windows, etc...)
ur basically gonna squeeze the +fog wire though there into ur driver side
NOTE: the driver side grommet hole is easier to access than the passenger side.
and if u look under ur steering wheel towards the panel, you will see a square hole...looks like it has some foam stuff around it. ur wire is gonna go through there...
you're going to have to unbolt a few clips on ur plastic fender wall
so ur gonna run it out through the square hole...and on ur fender, you will see a few small holes, and that is where ur going to continue running the +wire...
continue it to the front (ur bumper should be off), i grounded mine to my headlight bracket bolts.
dont put ur bumper on yet, plug in one fog and test it.
go back inside ur car and finsh up connecting all the wires
plug the batt back in, and test out ur foggies
if it works, connect both fogs, and put ur bumper on.
hope i helped you.
james
wiring:
hope i helped you.
james
well i just came back from the honda dealer and they gave me an installation guide...it seems that sl33pyriceboi's instructions matched the guide...and i found out that my motor mount ripped apart!
When I did my fogs. I had 2 harnesses. 1 for the inside that went from the switch to the fuse box thingy under the dash. and another that went from 1 fog to the other, then up to the passenger headlight. Thats all I had to do, it was easy besides breaking some of the clips because they didn't fit right inside so I used a female connector instead.
yeah, wherever your taking your power from, put a fuse in-line as close as possible, so if a short happens, it will cut off power to the circuit so no fire will happen.
https://www.civicforums.com/forums/7...r-console.html
hope that help...scroll down to see the DIY. i tink u have foglights for the 01-03 but i think it should still be similar...
jessicanicole
Jul 23, 2015 09:14 AM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
