2 many wires
Old Oct 25, 2006
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
2 many wires
im looking for a way to get rid of some of the wires going 2 my battery right now i have 1 for my amp 1 for under glow and one for interior stuff and strobes all are inline fused i just installed a power window kit and i kinda dont want another line comeing from the battery is there anything i can do where i can run a big cabel like mabey a 2 or 0 gauge and connect it to a fuse type thing on the inside where i can connect everything else or anyother ideas?
Old Oct 25, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
A Fused Distribution block. Nicest ones ive seen are street wires. linky for you
Old Oct 25, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
thanks i know one day im going to need this link
Old Oct 25, 2006
No problem bud, theres others out there that are alot cheaper. These are the nicest ones I found though.
Old Oct 25, 2006
ok so i found one of thoes things now i thinking about gauges i have a set of neons and underbody kit strobes a power window kit and a 3 port power port what gague wire you thing its a 6 terminal block with 30 amps out of each
Old Oct 25, 2006
A 4 should definately handle it but an 8 might. Im just guessing im not the greatest at electrical current draw.
Old Oct 25, 2006
the package says
wiring:Output Terminals -.250"x.032" QC rated 30A max Per circuit; Input terminals -#10-32 stud input rated 100A max
Recommended wire size:Input power #4-6; Output circuity #12-16
does that mean anything to anyone im guessing the #10-32 and #4-6 is gauge size but then which one do i use the 10-32 or the 4-6
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
