can you install deck under stock one???
Old Mar 15, 2002
yeah805's Avatar
yeah805 is an unknown quantity at this point
i want to install a pioneer deck right under my stock cassetts player, i wanted to know if it fits or would i have to get a kit to make it fit. how would i pop out the black lil space place without breaking it. i have an LX and would i have to but a wiring harnest for the back of my new deck. thanks and if theres any tips i should know before i go ahead and do it .
thanks again
Old Mar 15, 2002
mohawkboom's Avatar
why would you want to do that..you can't use both decks.. just replace the stock one or get a honda CD changer [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 15, 2002
yeah805's Avatar
why do you say i cant play both decks
??? why cant i
Old Mar 15, 2002
mohawkboom's Avatar
Because you do not have 2 antenna inputs, you do cannot run 4 speakers off 2 seperate decks. when you turn your ignition on both decks come on. which would cause a sphrt at your speakers and blow the internal amps in Both hu's.
This your brain.
This is your brain on drugs (well I'll post the pic later [IMG]i/expressions/face-icon-small-smile.gif[/IMG])
Cheers
Mohawk
Old Mar 15, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
I'm gonna have to disagree and agree with you at the same time mohawk. Yes you could put two decks in at the same time, but its more trouble then its worth. Like mohawk said, Why in earth would you want to do something like that. Just replace your stock HU!!! Do you have some sort of bond with your stock HU and don't want to part ways with it?
Old Mar 15, 2002
mohawkboom's Avatar
Alot of people get this Idea so that they can use the aftermarket HU's amps.. still have the tape player.. and CD player too [IMG]i/expressions/face-icon-small-smile.gif[/IMG]...it can be done yes..but it involves the wiring of alot of relays and creation of a pretty comlicated circuit. and it's just all out impracticle...
Old Mar 15, 2002
KevinFWB's Avatar
Hooking up the stock HU to an amp is actually inexpensive and easy. If you are satisfied with the stock head unit just add a High-to-low converter and hook up your amps. Will cost you about $20 for the parts to do this. You need a High-to-Low converted also called a line input converter. Some amps will even accept the direct speaker leads from a head unit.
Old Mar 16, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
i kinda had the same idea. but the factory wouldn't come on. for a stealth install.
Old Mar 19, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
What about replacing the stock HU with a new one (I'm looking at the Kenwood with the LCD, DVD, TV tuner and touch screen), then mounting a graphic EQ in the opening underneath? I've talked to a couple of installers about it, and they say it's entirely possible, and quite easy. . .is it worth it though?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 19, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
the area underneath could take anything that would mount in the top slot, except finding a mounting kit might not be so easy since it would be different than the one for the top. i never looked though because i never had the need, there might well be one that would be able to do it
159
Jul 5, 2015 09:54 PM
TiggerDX
Jun 18, 2015 01:43 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
Mokushi
Nov 1, 2001 02:40 PM
