Flashing LED
For every sprinkle I find, I shall kill you.
Flashing LED
Ok guys, long story short. My buddies girlfriend is in college and her car got broken into and her amp, subs, and what not got stolen. She doesn't have enough for an alarm so he wants the red flashing LED to make it at least look like she does. How would he go about hooking one up? Thanks!
here check this out http://www.7thgencivic.com/forums/sh...ight=alarm+led
radioshack has flashing led, then wire it to battery or other constant power. . i doubt it will ever drain the battery but if youre worried put a switch on it.
as RHCP said, you can do it like in my thread i had done a while ago, sorry the pics arent there anymore, so i posted them here instead. it is better than having it on a switch, cause this way it turns on automatically when you turn off the car, and turns off automatically when the car is on, so there is no need to remember to turn on the switch. Also, there is no worry to drain the battery with that led, a led would never drain a car battery, it draws almost no power. the flashing led i bought was 10$ at future shop. here's the link to the led: http://www.futureshop.ca/catalog/pro...47&catid=10908
Take it from me, you want to add a resistor with those leds that is a good amount larger than it needs be. Calculate the voltage from 14.0 not 12.0 when calculating the resistor to use. Get a higher wattage resistor than you need. Also if the LED is rated from say 3V DC to 5 V DC keep it below 4. It will last forever.
Thats all of the EE lecture im going to force on you for this one.
The resistor built in is fine, but chances are the flashing led is rated for an input of 12 volts. If you have a capacitor hooked up in your car the voltage will be over 12 volts, close to 12.5 or 13 volts when the car is off. You shouldnt be running the led this high.
If you dont have a capacitor, then i guess it doesnt matter. i forgot that this is only for when the car is off and thus most people will only have 12volts supplied to it.
i have a capacitor in my car and never had a problem. varad (the company of leds i use including the flashing led and the leds over my feet) makes led's to be used for when the car is running, cause i also have leds over my feet turn on when i turn on my headlights, and they never went out. But i do know what you mean cause, i had that problem with led's i bought on ebay, they had sent me resistors that were too low in resistance for those leds on 14v and always burnt the leds. IMO, all led company's should give the right resisters with the leds to go with 14.4v, cause they should know people will most likely run them with the car on
I just saw a BMW SUV with the alarm LED on the rear view mirror. Nice location, Hmmm....
The tolerance on some resistors is + or - 20%
Most super bright LEDs are just overdriven (not all) It can shorten their life.
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
shaejb15
Sep 12, 2015 01:02 AM
Mannimarco
Sep 7, 2015 10:01 PM
